Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > CpuIdle better than Win98SE's power management?
Forum Homebuilt Systems : General Homebuilt - CpuIdle better than Win98SE's power management?
Archived from groups: alt.comp.hardware.homebuilt (More info?)
I have an AMD Athlon XP 2500+ CPU on an ECS L7S7A2 motherboard. I'm
running Win98SE and CpuIdle, and I'm monitoring power consumption
using a wattmeter on the AC mains input. I notice that the system
consumes about 106W in the idle state with CpuIdle disabled. This
drops to about 75W with CpuIdle enabled. By my calculations, a power
reduction of 30W at the mains equates to about 21W at the PSU's
output, assuming an efficiency of ~ 70%. For a Vcore of 1.65V, this
means a reduction in CPU current of ~13A, assuming the CPU accounts
for the majority of the savings.
If I allow Windows' power management to switch the system to standby,
the power consumption is around 90W, some 15W *higher* than if the
system were idling. As expected, enabling or disabling CpuIdle does
not affect this figure. While it seems counterintuitive, I believe I'd
be better off disabling power management and allowing CpuIdle to
retain control of the CPU. Not what I expected at all ...
For those that don't have access to a wattmeter, the differences in
power consumption for the various states are reflected in the CPU
temperatures as reported by MBM, for example. In fact, I notice that
when my system returns from standby mode, CpuIdle believes it is
enabled when in fact the CPU temp indicates that it is disabled.
Correct operation, as evidenced by a drop in CPU temp, is restored
only after I toggle CpuIdle off and then on again.
- Franc Zabkar
Please remove one 's' from my address when replying by email.
Sponsored Links
> - Franc Zabkar
Interesting. Maybe Windows is using a simple HALT while CPUIdle uses a
deeper sleep HALT?
Reply to Anonymous
In article <115e430j4eblj1f@corp.supernews.com>, David Maynard says...
> deeper sleep HALT?
Windows 9x implements it differently to Windows NT. Win9x does
basically a half assed attempt at it. You benefit greatly from using
RAIN/CPUIdle on Win9x but the benefits aren't as great on Win NT as it
does the job properly.
Conor
Windows & Outlook/OE in particular, shipped with settings making them
as open to entry as a starlet in a porno. Steve B
Reply to Anonymous
In article <i0td51hthql7qk64lklgpfevulj5vcielc@4ax.com>, Franc Zabkar
says...
Absolutely spot on. The differences between CPUIdle and Windows
NT4/2000/XP are very minimal though. Win9x and WinNT use different
methods.
Conor
Reply to Anonymous
>>deeper sleep HALT?
Well, I was trying to figure out what "half assed" means.
Reply to Anonymous
On Sat, 9 Apr 2005 00:23:08 +0100, Conor Turton
>> deeper sleep HALT?
Do you have any evidence to support this, ie- specifics?
IMO, whether you like how Win9x does it or not, it does do
it properly and has same end result on power consumption
(and of course CPU temp).
More often the issue is whether the motherboard bios has the
proper chipset registers set for the bus-disconnect, and if
not, whether the CPU idling software added on top of the OS
recognizes that chipset and can toggle the chipset
registers. Without the registers flipped all the HLT
commands won't accomplish anything. Then again, some
boards' bios have a setting to enable or disable this
feature. Don't know about Sis chipset socket A, I do try to
avoid Sis based boards for any platform.
Reply to Anonymous
On Sat, 9 Apr 2005 00:23:59 +0100, Conor Turton
<conor@conorturton.com> put finger to keyboard and composed:
>says...
>methods.
AFAIK, one difference is that Windows versions 98 and above are ACPI
aware (or at least partially so), whereas Win95 and NT are not.
Another difference is that Win98 does not support the S3 state, but
Win98SE does.
Anyway, I tried the same comparison on a system running Win98SE, with
an AMD K6-2/450MHz CPU, SiS 5597 chipset, and AMIBIOS. Enabling or
disabling BIOS power management/APM did not affect the results for
either system.
K6-2 XP 2500+
Idling with CpuIdle disabled ---- 71W 106W
Idling with CpuIdle enabled ---- 52W 75W
Standby (S1, stopgrant mode) ---- 41W 90W
Standby (S3 mode, suspend to RAM) -------- 5W
ACPI was enabled in the Athlon system but was not available in the
K6-2 machine. The former's BIOS power management mode has three
options, S1, S3, or auto. CpuIdle defaults to S1 mode.
- Franc Zabkar
Reply to Anonymous
There are 1338 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
