Closed
Carbon Transistors Promise More Speed and RAM Capacity
  • RAM
  • Smartphones
  • Power
Last response: in News comments
July 19, 2012 5:12:34 PM
Cool story!
Score
-8
July 19, 2012 5:50:42 PM
Don't tease me, bring it to life. I want my 4 gig smartphone already.
Score
14
July 19, 2012 5:55:22 PM
I can't wait until tech like this comes to market. The pace of research just keeps accelerating and given the average ~10-15 year turnaround to market, we are going to start seeing some awesome advancements / new products at an ever increasing rate.
Score
5
July 19, 2012 6:04:28 PM
Can't wait for carbon and graphene to be used more and not just hear stories about them! Seems like a great time to be alive for a nerd!
Score
11
July 19, 2012 6:22:50 PM
Wondering who will have the first 1TB phone, and when :)
Score
5
July 19, 2012 6:34:33 PM
Instead of more memory I'd like more battery life. I don't need a phone with 8 GB of RAM whose battery lasts only a day.
Score
12
July 19, 2012 7:04:40 PM
Wouldn't the carbon just float away when it gets hot?
Score
-9
July 19, 2012 7:08:37 PM
Is graphene flammable?
Score
July 19, 2012 7:09:05 PM
An I the only one who lol'ed hard when read
Quote:
(TAU)
Score
-5
July 19, 2012 7:10:25 PM
HorheInstead of more memory I'd like more battery life. I don't need a phone with 8 GB of RAM whose battery lasts only a day.
stop watching porn on your phone and quit playing games and get back to work.
every phone i've had lasts for over 36 hours before needing a recharge.
Score
-9
July 19, 2012 8:05:27 PM
No. Not even slightly. It is the same material used in standard pencils (leads). Try and get that to burn. Even a blow torch as no effect!
Score
July 19, 2012 8:22:45 PM
derekulloWouldn't the carbon just float away when it gets hot?
This made me laugh. I guess/hope you're just fooling around, right?
Score
July 19, 2012 8:43:09 PM
There's a chronic shortage of RAM in smartphones?
Score
7
July 19, 2012 8:54:11 PM
Would like to see some number's on power consumption, most of the power consumption of FET's come from the gate leakage, from what little I read it sound's like the new construction method along with the carbon itself will vastly improve that, with silicon as lithography processes have gone smaller power consumption has remained relatively static due to balancing lower voltage requirements with increased current consumption. And why this focus on RAM? Solid state storage using this technology will finally signal the end of over 6+ decades of magnetic disks for primary storage.
Score
July 19, 2012 9:03:20 PM
No, the carbon would not float away. You're thinking of carbon's molecules with oxygen.
WyomingKnottIs graphene flammable?
You might be able to get it to burn at extremely high temperatures and in very high oxygen environments (might need pure or almost pure oxygen), but not in any situation that's even remotely likely with use of it in electronics. If you're asking this question because of carbon monoxide and carbon dioxide, well from what I know of them, they are generally made by burning chemicals that have carbon in them, not burning carbon itself.
Score
July 19, 2012 9:04:43 PM
Then buy an extended battery. Amazon often has them for dirt cheap for a wide variety of phones and my Evo 4G Android phone lasts two to three days of heavier usage with it and much longer with light usage.
Score
-3
July 19, 2012 9:10:06 PM
nitriumNo. Not even slightly. It is the same material used in standard pencils (leads). Try and get that to burn. Even a blow torch as no effect!
I did that once with a lighter. It wouldn't burn, but after a minute or two with a lighter, a piece of .7mm lead from a mechanical pencil did explode. It left a few very small scorched holes in a carpet that was a few feet away and the holes had little pieces of graphite shrapnel. Admittedly, it was far from being my brightest idea and could have had much worse results. However, like you're saying now, it didn't actually seem to burn the pencil lead. i'm not sure of why it exploded, but if I had to guess, there might have been impurities that caused it.
Score
July 19, 2012 10:15:29 PM
When last I checked (admittedly, a decade ago), C-60, or Buckminsterfullerene ("Bucky Balls") was not possible to manufacture. It could be detected in trace amounts when burning various fuels, if I remember correctly, but it was only a minute percentage of various other forms of resultant carbon, all mixed together. Does there now exist a way to manufacture and isolate economically feasible amounts of C-60?
Score
July 19, 2012 10:47:23 PM
that manWhen last I checked (admittedly, a decade ago), C-60, or Buckminsterfullerene ("Bucky Balls") was not possible to manufacture. It could be detected in trace amounts when burning various fuels, if I remember correctly, but it was only a minute percentage of various other forms of resultant carbon, all mixed together. Does there now exist a way to manufacture and isolate economically feasible amounts of C-60?
We've been able to manufacture graphene, fullerenes, nanotubes, etc. etc. for quite a while now, granted this might not be the easiest/cheapest thing to do. I don't know if it is economically feasible, but we've been improving with this sort of work very much and it might be. If transistors made from them can be produced on current fab's technology like these scientists claim, then it would seem that we can manufacture them fairly well.
Score
July 19, 2012 11:25:08 PM
Logically, a smaller and more compact RAM chip consumes less power.
Score
July 20, 2012 12:07:42 AM
in fact as memory could consume up to 20% of your battery, better Memory also implies more battery life ;-)
Score
July 20, 2012 3:46:24 AM
blame apple for starting the retarded thin war. ans blame everyone else for buying into it.
Kami3kCan't wait for carbon and graphene to be used more and not just hear stories about them! Seems like a great time to be alive for a nerd!
no, its a crappy time to be a nerd. most of the advancements we would have loved to be part of happened long ago, and its going to take a hell of along time before the advancements get far enough again to be interesting... unless you are in an academic environment.
Score
July 20, 2012 3:48:15 AM
f-14stop watching porn on your phone and quit playing games and get back to work.every phone i've had lasts for over 36 hours before needing a recharge.
No videos and no games? If you're not going to play games and watch videos, you can just get a Blackberry and stop bothering the people who own real smartphones.
Score
July 20, 2012 4:43:11 AM
Why is it almost always Israelis that make the latest technological breakthroughs? Is it because they are vastly outnumbered by the horde that they know if they didn't have superior technology then they would be overrun? I'm wondering if it would be better if the horde keeps threatening them or stops.
Score
-2
July 20, 2012 5:27:14 AM
Now make it happen!
Score
July 20, 2012 6:40:37 AM
IndignantSkepticWhy is it almost always Israelis that make the latest technological breakthroughs? Is it because they are vastly outnumbered by the horde that they know if they didn't have superior technology then they would be overrun? I'm wondering if it would be better if the horde keeps threatening them or stops.
A lot of discoveries, perhaps most, are made in other nations. We might hear about more Israeli discoveries/inventions/whatever, but even that doesn't seem true. Perhaps you've simply read about a few Israeli scientific breakthroughs lately instead of other discoveries. Tom's doesn't cover even nearly all of them.
Score
July 20, 2012 7:23:08 AM
When?, I want it now.
Score
July 20, 2012 9:25:27 AM
Yes, everything is combustible if the temperature is high enough, but the temperature it would combust would be significantly higher than what would cause you to set on fire first and even be completely reduced to ash, so try not to worry about it
Score
July 20, 2012 9:40:53 AM
Methinks there's a hidden agenda in your statement, would you even have raised this question if the breakthrough had happened in Manchester in the UK? That city had the first working computer, invented the contaceptive pill, first split the atom, two Manchester University scientists won the 2010 Nobel prize for physics for their graphene research, other famous scientists from Manchester include John Dalton, James Prescott Joule, Ernest Rutherford and Bernard Lovell.
But because Israel is mentioned in the story are you pushing some kind of antiSemetic angle?
Score
July 20, 2012 1:04:35 PM
Not sure about the "horde" theory, but Israel does have a lively high-tech industry. Lots of education, R&D, and the like over there.
Score
July 21, 2012 6:44:27 AM
Try putting 110V through the pencil core & see what happens (I already did...) It WILL burn after the surrounding wood burns.
Score
July 21, 2012 5:54:28 PM
madjimmsTry putting 110V through the pencil core & see what happens (I already did...) It WILL burn after the surrounding wood burns.
At what amperage?
Score
March 27, 2013 11:15:20 PM
blazorthonAt what amperage?
Dude, look on youtube... Its standard US outlet voltage & amperage.
Score
