Archived from groups: alt.comp.hardware.pc-homebuilt,alt.comp.hardware.homebuilt (More info?)
I'm building a HTPC with a Pentium 4 3.2ghz Northwood CPU, two 512meg
sticks of Mushkin PC3200 ram, Zalman CNPS 7000-A AlCu heatsink, Arctic
Silver Ceramique thermal compound, Intel 865 PERL motherboard. and a ATI
Radeon 9800 Pro video card. I'm using a 400w Seasonic Super Silencer
power supply and a Silverstone LC-10 case.
I've finally got the motherboard to post (see my other message titled
Motherboard will not POST). But now I've having a problem with the CPU
temp. At the BIOS screen the CPU temp is 43 deg C after 1 hour of
running. This is is with the motherboard lying on the table in the open
air. If I put it in the LC-10 case even with all the fans hooked up the
CPU temp rises to 50 deg C according to the BIOS and I dont have the
hard drive, video capture card or DVD drive power cables connected. Yet
the heatsink is barely warm when I touch it.
I"ve taken off the heatsink, cleaned it and the CPU with Goof-Off (as
recommended by Arctic Silver) and 91% alcohol and reapplied thermal
compound 3 or 4 times and end up with the same temps. I even tried a
Seasonic Super Turnado with the 120mm fan and the temps inside the case
stayed the same. I'm going to be adding a lot of heat producing
components (more hds, more video capture cards) so I need to figure out
why the CPU temp is so high. I dont want to add more or higher powered
fans it I can help it because of the added noise.
On 01 Jun 2005 05:01:24 +0500, "Tom Mislewski"
50C is not high enough to be concerned about, it may be
about average for an OEM box with an upper-end Northwood
running quietly. However, the typically running,
mostly-idle state of the CPU is not a good measure of the
adequacy (or inadequacy) of a heatsink - you need test it by
running at full load for an extended period of time. For
example, Prime 95's Torture Test for > 30 minutes in the
highest ambient (room) temps the system is likely to
encounter.
When you remove the heatsink, I presume you do clearly see
the imprint of the CPU on it's base? That is one indicator
of the contact quality, if it has squished out all but the
needed amount of thermal compound. Some people put too much
compound on the CPU, especially with CPUs having a heat
spreader (which causes a lower presser contact between the
CPU and 'sink, will not squish out as much compound as the
older open-core flip chips (like a P3 or Athlon XP) did.
With that in mind, you might consider wiping off the bulk of
the thermal compound (NOT trying to remove every last
molecule of it, just using a lint-free cloth to get most of
it off- so it's fairly clean but not necessarily having all
the compound removed from any pores in the heatsink base.
Then try applying only a 1.5 grain-of-rice sized blob of
thermal compound in the exact center of the CPU head
spreader. After applying the heatstink that will spread
out.
Also note that with the modern synthetic ester based thermal
compounds (like Arctic Silver, Alumina, Ceramique, et al) it
may take a few days and thermal cycles (machine turning off
and cooling down a few minutes) for the compound to reach
maximum effectiveness. In other words, once you are
confident the compound is applied correctly, wait a few days
for that last ~ 4C temp drop before making final judgement-
that is assuming the initial temp is at least low enough
that the final expected result would be acceptible.
>stayed the same.
I don't know about your board but "system" temp reports are
more often of a different chip on the motherboard- are not
an indicator of case temps but rather than chip which is
it's own source of heat.
A closed case with good large unobstructed areas for intake
and exhaust (regardless of whether the particular case has
fans for both of those roles) will help keep parts cool by
reducing the air recirculated through the heatsink.
Your options at this point should include assessing the case
itself, if it allows good intake and exhast, and the same
goes for the power supply. In particular, avoid
mostly-obstructed stamped-in-metal fan grills, or front
plastic bezels that have similar impedance to airflow.
If you feel the case is ready then add the parts. If it's
not ready you might do some cutting on it before adding the
parts- you can always turn down ur unplug a fan later, it'd
be easier than having to strip the system down to modify the
case later. Then again, one popular solution is to put a
fan in the side panel, as this allows system to remain whole
and even running by using the removalable panel. Just be
sure that any changes in flow would not negatively impact
the HDD cooling.
Archived from groups: alt.comp.hardware.homebuilt (More info?)
>I'm building a HTPC with a Pentium 4 3.2ghz Northwood CPU, ...
>Silver Ceramique thermal compound, Intel 865 PERL motherboard. .......
>CPU temp rises to 50 deg C according to the BIOS ... Yet
temps are normal from onDie sensor ...!
Regards , SPAJKY ®
mail addr. @ my site @ http://www.spajky.vze.com 3rd Ann.: - "Tualatin OC-ed / BX-Slot1 / inaudible setup!"
"Tom Mislewski" <junkthis@nospammers.com> wrote in message
news:100133011116917.NC-1.54.junkthis@news.calweb.com...
How much space between end of video card and drive cage? Review of that
case at http://www.ocmodshop.com/default.aspx?a=250&p=716 mentions poss, air
flow problems. However, 50C is not that high for a P4. Quiet PSU may shift
less air than standard PSU. Make sure you keep cables tidy. Use Round data
cables if poss.
Mike.
On Wed, 1 Jun 2005 21:43:03 +0100, "Michael Hawes"
>cables if poss.
> Mike.
Great link!
Yes that case has very poor airflow, though I'd be more
concerned about the typical problems seem with similar
desktop cases, high impedance to flow from the front intake,
rear exhaust, and front bezel.
"Spajky" <Spajky@##volja.net> wrote in message
news0ur911cgm9ung7i9vbnedei9ggpkens1j@4ax.com...
Exactly. I have been fighting with temps all week on this new Socket 775
Intel with I-630 and finally discovered that temps are read on-die and
10degs+ over what we are used to seeing is quite normal and expected. I just
have a lot of problems seeing idle temps between 48 and 51c which is over
15degs higher than I am used to seeing. Stress tests bring it up to the low
60s, but it is stable as a rock even with a 20% overclock. It seems that
although we see higher idle temps, the range of temperature changes from
idle to high stress is smaller. At least, that is what I am seeing. I am
usually pretty confident in my ability to keep a cool and quiet case, but
with this one all I can do is keep it quiet no matter what I do ......:-)
Ambient (case) temps are 31c. MB temp is 33-36c constant. I don't know what
else I can do.
> running quietly. ...
Yes, I checked around some more and found that 43C - 50C temps is indeed
common on 3 ghz Northwoods. I was mislead by the fact that many articles
stated that temp should be about 10C to 15C lower than that.
> out.
I followed your advice and tried reinstalling the heat sink and
reapplying the thermal paste one more time. This time my temps with the
motherboard on the table are 39C but my case temps are still 50C. I'll
live with these temps.
Thanks for letting me know what the normal temp range for a 3.2 ghz
Northwood is Spajky. I'm not so worried about my temps any more.
> > running. .....In the case even with all the fans hooked up the
> cables if poss.
> Mike.
Mikr, thanks for telling me my temps are OK for a 3.2 Ghz Northwood.
I've also taken your advice and switched to round IDE cables.
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
> ATI
> open
> the
> Yet
> case
> out
Hi,
Although 50C isn't a great emergency with this chip, it is way too
high for at-rest with not much hooked up. One has to explore the
following things:
Heat is not as much to do with the number of fans (after the first
two or three), but the strategic placement and direction of air flow
within the case.
Do check the following in this vein:
1) Make sure you have your heatsink fan blowing DOWN and not up.
2) Do make sure that you are not putting TOO MUCH thermal paste
between your heatsink and CPU. (read artic silver instructions and a
little dab will do you)
3) Make sure you have a rear fan blowing hot air OUT of the case.
4) Make sure you have a front intake air fan blowing cool air IN.
5) Make sure any other fans that you have do not create a turbulance
with the air flow listed above.
6) Get some of the round cables (IDE) for drives to eliminate the
blockage that can be caused by the old ribbon cables. The old ones do
restrict air flow and block cooling from getting to components.
7) A little trick that I learned while building computers was to take
the little PCI strap covers on the back of the case in unused PCI slots
and drill holes in them to allow air and heat to excape and to flow out
the back of the case through those enclosures. Of course, if you remove
them and put in a PCI card, then they aren't there, so you can't do
that.
Normal for this processor should be (in the case) between 33C to
42C at rest and under stress with everything connected approximately
48C to 54C. We see this every day in the process of building
computers. I would be very concerned with any temp for any periond of
time over 60C, although you need to know that the company says they can
operate at temps higher without damage. I do know that heat kills, so
proceed with caution.
I presently (not for customers, but for personal usage) am running
two Northwoods in two different cases and with only a front and rear
fan in each, and they both are even below the temps that I listed above
for you. This chip does not as a rule run hot and I am using the stock
Heatsink and fan on both of them. Both of my computers are running
high end graphics cards of the ATI brand and one gig of memory in each
with two hard drives in one and three in the other (all 7500 rpm
drives), two optical drives in each and a floppy with each having two
extra USB drives and a camera always connected. Therefore, our items
would be very comparable. Heat is just not a problem with this chip
and setup.
Hope at least one thing I have given you provides some relief.
Good luck and let us know if we can help.
