Archived from groups: alt.comp.hardware.homebuilt (More info?)
When I first put my system together it worked fine but it has suddenly
started to hang at the PCI Device Listing screen. The system will boot
up normally but it will sit at this screen for about 3 minutes before it
will actually boot into Windows XP.
I don't think I've changed any settings in windows or in the BIOS and
the system operates perfectly once Windows is loaded.
Any advice?
Asus A8N-SLI
2x6800 GT
2GB DDR RAM
Athlon 64 4000+
In article <MPG.1d2480a235fe22a7989b78@nntp.dsl.pipex.com>, Stoneskin
says...
> Any advice?
> Asus A8N-SLI
> 2x6800 GT
> 2GB DDR RAM
> Athlon 64 4000+
> Two hard drives on SATA
> Western Digital 200GB
> Western Digital 250GB
Usually that's caused by the computer trying to find the MBR of the
HDD.
Conor
-You wanted an argument? Oh I'm sorry, but this is abuse. You want room
K5, just along the corridor. Stupid git. (Monty Python)
Stoneskin left a note on my windscreen which said:
> > HDD.
> But it does find it eventually - which seems odd. I can imagine if the
> MBR is corrupted somehow it would fail to boot completely.
> What can I do, besides a full reformat to sort it out?
I feel like such a noob! Solved the problem by.. wait for it..
taking the cd out of my dvd drive.
Obviously the PC was looking to boot from the cd I had in the drive and
took a while to figure out it couldn't.
Stoneskin
