G
Guest
Guest
Archived from groups: alt.comp.hardware.homebuilt (More info?)
Hi -
I hope I can ask a question here on a non homebuilt system....
I have an older system:
SE440BX-2 Mother board
Dell Dimension XPS T450
Intel PIII 450 MHZ
Windows XP
It had the following SDRAM memory config:
Slot0 - Empty
Slot1 - 128 MB
Slot2 - 64 MB
I went to upgrade using 2 PC100 128 MB DIMMS from another system that
was coming down. The two DIMMS
The new config was:
Slot0 - 128 MB
Slot1 - 128 MB
Slot2 - 128 MB
But the system would freeze shortly after boot.
I removed the 128 from Slot0 and it worked fine.
I added the known good 64 MB DIMM to slot 0 and again problems, this
time with a PC Serial Presence Detect error message during POST. I
didn't even bother to let it finish boot.
I removed the 64MB and it worked fine again. The upshot is it
seems anything I put in Slot0 does not work and screws up the system.
Any ideas? Do I have to set a jumper, switch or some BIOS setting?
Maybe slot0 is just bad?
Thanks in Advance-
Hi -
Intel PIII 450 MHZ
Windows XP
Slot0 - Empty
Slot1 - 128 MB
Slot2 - 64 MB
The new config was:
Slot0 - 128 MB
Slot1 - 128 MB
Slot2 - 128 MB
Thanks in Advance-
