Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Wireless Mouse Problem
Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.pc-homebuilt (More info?)
I set up a third machine, an old PIII 1GHz system running XP Pro SP2, and
installed a Logitech MX 700 wireless mouse,
and every so often it disconnects.
I'm using the latest mouse and motherboard (Abit SE6) drivers, but can't
figure out why it's doing that.
It's very annoying, especially when playing games.
I'm curious to know if anyone else has experienced anything similar.
Thanks.
JL
ALEA IALCA EST............Julius Caesar
Sponsored Links
> SP2, and installed a Logitech MX 700 wireless mouse,
> but can't figure out why it's doing that.
> similar.
Yes. Try replacing/recharging the batteries.
Reply to Anonymous
& try another channel. Usually has three channels. Could be interference
causing it.
"John Doe" <jdoe@usenet.love.invalid> wrote in message
news:Xns96838DB8104Awisdomfolly@207.115.63.158...
>> similar.
Reply to Anonymous
On Mon, 27 Jun 2005 23:34:31 -0400, "John Lettiere"
>Thanks.
In addition to what John & Bruce mentioned, try keeping both
and mouse and base station at least a few inches away from
metal objects, even line-of-sight if possible (though
theoretically not necessarily with non-infrared mice, it
would tend to maximize the signal still).
Also if you are in relatively close proximiate to anyone
else, even apartment/neighbors, whether there is any chance
they're using something wireless, even a kids' remote
control car. Did it mention the frequency rage it uses
(perhaps in the back of the manual) ?
Reply to Anonymous
In article <bz3we.8176$UG3.4771@fe11.lga>, John Lettiere says...
Its a transmitter/receiever and uses RF. Anything can potentially
interfere.
Conor
-You wanted an argument? Oh I'm sorry, but this is abuse. You want room
K5, just along the corridor. Stupid git. (Monty Python)
Reply to Anonymous
Done that.
Just got new rechargeable batteries last week, and it still does it
(disconnects).
Thanks John.
John Lettiere GM
JL Computer Services & Consulting.
http://perfcomp.homestead.com/Prefcomp2.html
You Don't Need A Weatherman To Know Which Way The Wind Blows.....Bob Dylan.
>> similar.
Reply to Anonymous
>causing it.
I did see anything about changing channels in the documentation.
How do I change the channels?
John Lettiere GM
"BruceM" <bruce@@hotmail.com> wrote in message
news:42c0e6cc$1@duster.adelaide.on.net...
>causing it.
>>> similar.
Reply to Anonymous
Yes I've done that.
I moved the base about 6 inches to the shelf above the computer.
You have me thinking about the possible metal interference; could it be
because the case I have for the old system I'm using the mouse on now is
steel,
where as the other newer systems case was aluminum?
The only other wireless device that is in close proximity is my laptop (8
feet away), but it never interfered
with the mouse before.
Thanks Kony.
John Lettiere GM
"kony" <spam@spam.com> wrote in message
news:58v1c1trtqmfqhkagsfh8iq138r23j8dp7@4ax.com...
>>Thanks.
Reply to Anonymous
>>interference causing it.
It has to be there.
I think your MX700 cordless optical mouse has two channels.
If you cannot find it in the documentation, try Logitech's web
site for information about connecting/receiver stuff
http://logitech-en-amr.custhelp.co [...] ?c=US&l=EN
Search for answer ID 878
Or this if it works
http://tinyurl.com/dkg3w
Good luck
Reply to Anonymous
On Tue, 28 Jun 2005 10:25:51 -0400, "John Lettiere"
>Yes I've done that.
I would move it even further away if possible.
>steel,
Either will be same problem (potential). The based should
have no metal around it for optimal results. Around it
meaning anywhere... it's just that most people can tolerate
a little degradation and theirs still work, but they may not
have exact same setup as you.
WIreless devices need not be in closer proximity to be a
problem, only have a strong enough signal on the right
(wrong) frequency range. Something fitting this criteria
that's 100 yards away could even do so, though that might be
far enough for typical consumer/unlicensed equipment to not
be a problem.
Reply to Anonymous
> Or this if it works
> Good luck
Thanks John, I'll try this.
John Lettiere GM
news:Xns9683606D568ECwisdomfolly@207.115.63.158...
> It has to be there.
> Or this if it works
> Good luck
Reply to Anonymous
>> http://logitech-en-amr.custhelp.com/cgi-
bin/logitech_en_amr.cfg/php/enduser/entry.php?c=US&l=EN
>> Or this if it works
>> Good luck
When?
Reply to Anonymous
There are 1341 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
