HELP! Power Supply burned out, Please!
Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.homedesigned,alt.comp.hardware.pc-homebuilt (More info?)
Hello all,
Im a new pc builder and have just ran into an enormous problem. First
let me tell you my specs, everything is brand new, except for the
power supply and optical drives:
ANTEC TruePower 480W
ASUS A8N-Deluxe SLI
AMD Athlon 64 3200
WD Raptor 74GB SATA
Maxtor MaxLine III 250 GB SATA
ATI Radeon X700 PCI-express 256MB
Sound Blaster Audigy 2 ZS
Pioneer DVD-107D burner
Creative 52x CD drive
Floppy Drive
3x Corsair 512MB DDR-DIMM ValueSelect
Couple fans
I built this pc, reading all directions really carefully, took me 3-4
hours, cuz I wanted to make sure everything was correct. I double
checked everything. I plug all the correct wires etc....
So now I come to turning on the pc. I first turned on the power
supply... I saw a light turn on in my case, i believe that was my
motherboard, so thats good. I would like to stress that the computer
was NOT IN USE, this was the first time I turned it on. So now to turn
on the pc, i pressed the ON button......
DAMN, the thing i feared most occurred. I heard a pop and saw a flash,
and the pc did not turn on. A real bad odor came out of the power
supply. So Im assuming the power supply burned out....But PLEASE, for
I cannot afford another computer, tell me that hopefully the other
pieces of hardware are fine.....Again, the computer was NOT IN USE,
this was the first turn on.....
Please, your help and suggestions are greatly appreciated.
Thanks
Posted using the http://www.hardwareforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.hardwareforumz.com/Home-Built-HELP-Power-Supply-burned-ftopict58633.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.hardwareforumz.com/eform.php?p=296951
18 answers Last reply
More about help power supply burned please
  1. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.homedesigned,alt.comp.hardware.pc-homebuilt (More info?)
    "WhiteTree" wrote:
    > Hello all,
    > problem. First let me tell you my specs, everything is brand
    > new, except for the power supply and optical drives:
    > ASUS A8N-Deluxe SLI
    > AMD Athlon 64 3200
    > WD Raptor 74GB SATA
    > Floppy Drive
    > Couple fans
    > me 3-4 hours, cuz I wanted to make sure everything was
    > correct. I double checked everything. I plug all the correct
    > wires etc....
    > power supply... I saw a light turn on in my case, i believe
    > that was my motherboard, so thats good. I would like to stress
    > that the computer was NOT IN USE, this was the first time I
    > turned it on. So now to turn on the pc, i pressed the ON
    > button......
    > a flash, and the pc did not turn on. A real bad odor came out
    > of the power supply. So Im assuming the power supply burned
    > out....But PLEASE, for I cannot afford another computer, tell
    > me that hopefully the other pieces of hardware are
    > fine.....Again, the computer was NOT IN USE, this was the
    > first turn on.....
    > Thanks
    Just realized this, my room has no electricity, certain sockets,
    lights dont work, tv dont work....hmmmm
  2. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.homedesigned,alt.comp.hardware.pc-homebuilt (More info?)
    Suddenly, without warning, WhiteTree exclaimed (09-Jul-05 7:41 AM):
    > "WhiteTree" wrote:
    > > Hello all,
    > > ASUS A8N-Deluxe SLI
    > > AMD Athlon 64 3200
    > > WD Raptor 74GB SATA
    > > Floppy Drive
    > > Couple fans
    > > wires etc....
    > > button......
    > > first turn on.....
    > > Thanks
    Um... did you check the voltage slider, and make sure (if you're in the
    US) that it was set for 110, and not 240?
    jmc
  3. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.homedesigned,alt.comp.hardware.pc-homebuilt (More info?)
    > > ASUS A8N-Deluxe SLI
    > > AMD Athlon 64 3200
    > > WD Raptor 74GB SATA
    > > Floppy Drive
    > > Couple fans
    > > wires etc....
    > > button......
    > > first turn on.....
    > > Thanks
    One thing to look at: On the I/O panel, in the back, they have these little
    pieces on each opening for your ports that are bent inward toward the inside
    of the case on most panels supplied with the motherboard. Sometimes, when
    you mount your motherboard, you can get one of these things bent - touching
    a port and possibly shorting out when you turn it on. This can cause similar
    things like you've described, often shorting out some expensive internal
    parts with it.
    Take a close look at where your ports come out through your I/O panel on the
    back of your case and make sure this is not what happened.
  4. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.homedesigned,alt.comp.hardware.pc-homebuilt (More info?)
    All you can do is replace the PSU and pray
    "WhiteTree" <DoNotEmail@HardwareForumz.com> wrote in message
    news:7_296966_5c31160c5495bad2d979c9932d049875@hardwareforumz.com...
    > "WhiteTree" wrote:
    > > Hello all,
    > > ASUS A8N-Deluxe SLI
    > > AMD Athlon 64 3200
    > > WD Raptor 74GB SATA
    > > Floppy Drive
    > > Couple fans
    > > wires etc....
    > > button......
    > > first turn on.....
    > > Thanks
  5. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.homedesigned,alt.comp.hardware.pc-homebuilt (More info?)
    WhiteTree wrote:
    > Hello all,
    > ASUS A8N-Deluxe SLI
    > AMD Athlon 64 3200
    > WD Raptor 74GB SATA
    > Floppy Drive
    > Couple fans
    > Thanks
    A power supply can take everything else with it. If you kept your
    receipts, you should be able to return/exchange the merchandise.
  6. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.homedesigned,alt.comp.hardware.pc-homebuilt (More info?)
    "" wrote:
    > WhiteTree wrote:
    > > Hello all,
    > problem. First
    > for the
    > > ASUS A8N-Deluxe SLI
    > > AMD Athlon 64 3200
    > > WD Raptor 74GB SATA
    > > Floppy Drive
    > > Couple fans
    > took me 3-4
    > double
    > power
    > was my
    > computer
    > now to turn
    > saw a flash,
    > power
    > PLEASE, for
    > other
    > IN USE,
    > > Thanks
    > your
    > merchandise.
    I bought all the components online from newegg.com. Do they deal with
    these types of accidents? Or do they not deal with accidents due to
    human error? That would be real nice if they could replace the
    merchandise...
    Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.hardwareforumz.com/eform.php?p=297187
  7. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.homedesigned,alt.comp.hardware.pc-homebuilt (More info?)
    "WhiteTree" <UseLinkToEmail@HardwareForumz.com> wrote in message
    news:7_297187_a27bb4a495dfa2697d5a45907563b6f0@hardwareforumz.com...
    > "" wrote:
    > > WhiteTree wrote:
    > > > Hello all,
    > > problem. First
    > > for the
    > > > ASUS A8N-Deluxe SLI
    > > > AMD Athlon 64 3200
    > > > WD Raptor 74GB SATA
    > > > Floppy Drive
    > > > Couple fans
    > > took me 3-4
    > > double
    > > power
    > > was my
    > > computer
    > > now to turn
    > > saw a flash,
    > > power
    > > PLEASE, for
    > > other
    > > IN USE,
    > > > Thanks
    > > your
    > > merchandise.
    > merchandise...
    first check for obvious burns- scorches -smells for all the hardware
    then, get a PSU and power up just the mboard and proceed to add on
    peripherals, checking for boot as you go.
    Asking outright for newegg to replace your stuff because you didnt buy/check
    the PSU, is not going to happen.
    request
    > Topic URL:
  8. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.homedesigned,alt.comp.hardware.pc-homebuilt (More info?)
    WhiteTree wrote:
    > "" wrote:
    > > WhiteTree wrote:
    > > > Hello all,
    > > problem. First
    > > for the
    > > > ASUS A8N-Deluxe SLI
    > > > AMD Athlon 64 3200
    > > > WD Raptor 74GB SATA
    > > > Floppy Drive
    > > > Couple fans
    > > took me 3-4
    > > double
    > > power
    > > was my
    > > computer
    > > now to turn
    > > saw a flash,
    > > power
    > > PLEASE, for
    > > other
    > > IN USE,
    > > > Thanks
    > > your
    > > merchandise.
    > merchandise...
    No offense but what evil thing did Newegg do that they should suffer the cost?
  9. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.homedesigned,alt.comp.hardware.pc-homebuilt (More info?)
    > ASUS A8N-Deluxe SLI
    > AMD Athlon 64 3200
    > WD Raptor 74GB SATA
    > Floppy Drive
    > Couple fans
    > took me 3-4 hours, cuz I wanted to make sure everything
    > was correct.
    > the power supply... I saw a light turn on in my case,
    > i believe that was my motherboard, so thats good.
    > and saw a flash, and the pc did not turn on. A real bad
    > odor came out of the power supply.
    > sockets, lights dont work, tv dont work....hmmmm
    Generally, Antecs are good but have been known to fail
    right at turn-on, but it's possible your computer shorted
    it and its protection failed to work as advertised.
    Regardless, you're covered under Antec's 3-year warranty.
    Before you receive the replacement, strip the computer down
    to its bare essentials and check very carefully for shorts
    between the motherboard and case. Verify that the minimal
    system works before you reinstall the rest of the hardware
    (reinstall incrementally).
  10. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.homedesigned,alt.comp.hardware.pc-homebuilt (More info?)
    WhiteTree wrote:
    > > hardware
    > > add on peripherals, checking for boot as you go.
    > Ive never done this so, what happens if I power up just the mother
    > board without any peripherals, you need the video card to see anything
    > on the monitor, and harddrives?
    Monitors are one of the biggest scams ever perpetrated on the computer
    users because even without one it's easy to see what the computer is
    doing -- if you truly believe.
  11. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.homedesigned,alt.comp.hardware.pc-homebuilt (More info?)
    Howdy!
    "jmc" <NOnewsgroupsSPAM@NOjodiBODY.HOMEus> wrote in message
    news:3j9bu9Fone6hU2@individual.net...
    That's not the problem -setting for 110 when he's on 240V service
    WILL cause a flash and a loud "POP!"
    Setting 240 in the US tends to make one just not work as it's
    getting about 1/2 the voltage it needs ...
    RwP
  12. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.homedesigned,alt.comp.hardware.pc-homebuilt (More info?)
    > message
    > > "" wrote:
    > > > WhiteTree wrote:
    > > > > Hello all,
    > > > problem. First
    > except
    > > > for the
    > > > > ASUS A8N-Deluxe SLI
    > > > > AMD Athlon 64 3200
    > > > > WD Raptor 74GB SATA
    > > > > Floppy Drive
    > > > > Couple fans
    > carefully,
    > > > took me 3-4
    > correct. I
    > > > double
    > etc....
    > the
    > > > power
    > that
    > > > was my
    > the
    > > > computer
    > So
    > > > now to turn
    > and
    > > > saw a flash,
    > the
    > > > power
    > out....But
    > > > PLEASE, for
    > hopefully the
    > > > other
    > NOT
    > > > IN USE,
    > appreciated.
    > > > > Thanks
    > kept
    > > > your
    > > > merchandise.
    > accidents due to
    > the
    > > merchandise...
    > hardware
    > add on
    > didnt buy/check
    > request
    > standards
    > > Topic URL:
    > abuse:
    Thanks
  13. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    > mother board without any peripherals, you need the video card to
    > see anything on the monitor, and harddrives?
    If you're talking about the bare minimum components.
    No disk drives.
    .... mainboard and CPU (always make sure the CPU fan is running)
    .... one stick of memory
    .... video card
    .... keyboard
    .... monitor
  14. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.homedesigned,alt.comp.hardware.pc-homebuilt (More info?)
    On Sun, 10 Jul 2005 15:07:21 -0500, "Ralph Wade Phillips"
    <ralphp@techie.com> wrote:
    >Howdy!
    > RwP
    Good point.
    I can't speak for everyone but when I have a new PSU, I
    power it on BEFORE ever attaching it to expensive equipment.
    Even if someone didn't have the skill or DVM to check it,
    manufacturing flaws may be revealed with this simple step.
    Seldom if ever does a PSU warranty cover the connected
    equipment.
  15. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.homedesigned,alt.comp.hardware.pc-homebuilt (More info?)
    On 10 Jul 2005 15:36:57 -0400, WhiteTree
    To get output to the monitor you'll need at a minimum:
    CPU
    Heatsink (& fan)
    1 memory module
    video card (or integral video if/when so equipped)
    A keyboard is not necessary, UNTIL you have the need to
    input, for example entering the bios configuration menus.
  16. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.homedesigned,alt.comp.hardware.pc-homebuilt (More info?)
    WhiteTree <UseLinkToEmail@HardwareForumz.com> :
    My guess is that the rest of your components are fine -- assuming that you
    really did have everything hooked up correcty. Over the years I've had a
    similar situation happen about 15 times and nothing was ever lost.
    Hopefully it will be the same for you. Good luck.
  17. Archived from groups: alt.comp.hardware.homedesigned (More info?)
    On 9 Jul 2005 02:41:23 -0400, WhiteTree
    <UseLinkToEmail@HardwareForumz.com> wrote:
    >Hello all,
    >ASUS A8N-Deluxe SLI
    >AMD Athlon 64 3200
    >WD Raptor 74GB SATA
    >Floppy Drive
    >Couple fans
    >Thanks
    Agree with most on this.Strip it down and check for shorts on mb and
    case.another power supply may work but check first.If you can't get
    any beep codes at powerup/boot,then it's the power supply,but i would
    look for an underlying problem that caused it in the first place.
  18. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.homedesigned,alt.comp.hardware.pc-homebuilt (More info?)
    "spodosaurus" <spodosaurus@_yahoo_.com> wrote in message
    news:42cf9b42$1@quokka.wn.com.au...
    > WhiteTree wrote:
    > > Hello all,
    > > ASUS A8N-Deluxe SLI
    > > AMD Athlon 64 3200
    > > WD Raptor 74GB SATA
    > > Floppy Drive
    > > Couple fans
    > > Thanks
    And say what? The poster said the PS wasn't new. The other stuff won't be
    covered.It's not faulty. Maybe the P/S was a dud but it won't matter to
    newegg or any other retailer. How can they cover something like this? I
    wouldn't.
Homebuilt Hardware Power Supplies Systems
