Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.homedesigned,alt.comp.hardware.pc-homebuilt (More info?)
Hi,
Recently i built a Intel Celeron 2.4Ghz PC
I now want to get Windows XP Home to install
This is where the problems start
:cry: :cry: :cry: :cry:
For some unknown reason it hangs at the XP boot screen after loading
the windows sepup files.
Could someone please inform me whats going wrong
Thanks in advance
Mark
Posted using the http://www.hardwareforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.hardwareforumz.com/Home [...] 59846.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.hardwareforumz.com/eform.php?p=302585
Sponsored Links
It could be bad RAM, motherboard, etc. Do you have different RAM
to try? Did you try running Memtest86 on a boot disk?
http://www.memtest86.com/
Kevin Chalker, Owner (KC COMPUTERS)
E-mail: kc@kc-computers.com Web: www.kc-computers.com
Internet dealer since 1991!!! See WWW.RESELLERRATINGS.COM!!!
Reply to Anonymous
You don't have a removable disk such as a Castlewood Orb or Zip drive, do
you? I had an Orb and WinXP wouldn't boot without a disk mounted. It would
hang at the "Knight Rider" screen until a disk cartridge was inserted.
Reply to Anonymous
- 0 +
Archived from groups: alt.comp.hardware.homebuilt (More info?)
On 4 Aug 2005 20:37:41 -0400, markthedaemon
<UseLinkToEmail@HardwareForumz.com> wrote:
>Hi,
>Thanks in advance
>Mark
As has been mentioned by KC Computers it could be faulty memory. I
have experienced similar problems with a faulty Hard Drive being the
culprit. I also had similar problems caused by the CDRom not being up
to the job.
KM
Reply to km
markthedaemon wrote:
> Hi,
> Thanks in advance
> Mark
As Ruel suggested, it could be a piece of hardware that XP does not
know how to handle. It is wise to remove any hardware that can be
removed when encountering such a problem. Once Windows is loaded,
install one piece of hardware at a time. That way if it fails to detect
the hardware or boot properly, you can remove the hardware and seek the
proper driver.
It might also be what Kevin suggested. It is always wise to run a
memory test before doing any additional software trouble shooting when
Windows won't load properly.
Reply to ken
"markthedaemon" wrote:
> Hi,
> loading the windows sepup files.
> Thanks in advance
> Mark
Thanks a lot,
I’ll try your sugestions and see what happens...
Reply to Anonymous
Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > XP Installation Help
There are 876 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
