G
Guest
Guest
Archived from groups: alt.comp.hardware.homebuilt (More info?)
Hi, I having serious trouble with the connector block/pin connector,
I'm using a MSI K8N Neo Platinum nForce3 250 (Socket 754) (MS-7030)
Motherboard. There are two pin connectors with this motherboard JFP1
and JFP2, both have the power LED connector on each one, but I've only
got one lead (green +/white -) which one does it go in? Also here is a
description of the connector pins thus far.
I've placed the HDD pin into the connector block which stats HDD
(1and3) making sure the colored wire is placed into the + and the
white wire is in the "-" slot.
Next to this is the Reset (5and7) switch again I place the reset pin
into the connector leaving the last connector block pin spare (9).
Now I place the Power SW (6and8) pin into the connector block, as
earlier the "-" is the white wire and the "+" is the colored wire.
Pin 10 is left blank.
Now with regards to JFP2.... I noted that the speaker ( pin 2.4.6.8)
is not polarised so it can be connected either way round??? Now here
is the main problem the Power LED (green +/white -) does this go into
the JFP1 slot or the JFP2 slot? And what is the purpose of the GND
pin?
Thank-you in advance.
pin?
