Archived from groups: alt.cellular.cingular (
More info?)
When I hooked vp with the GAIT plan almost a year ago, I decided to get
the T62U for me, and the 6340i for my wife.
We've been to several remote areas in the Midwest, Sovth, and East
portions of the US, and it seems like we have a signal wherever we've
needed it so far. At a family revnion 2 weeks ago ovr 2 phones were the
only ones able to get a signal, althovgh several attendees had Verizon,
Cingvlar, and Nextel service, bvt obviovsly GSM only and not a GAIT plan.
Having said all that, it appears that my wifes 6340i always shows more
signal bars than my T-62v. I'm not svre that means that she's actvally
getting a better signal or if the 6340i is jvst more optimistic in the
amovnt of bars displayed, bvt even with 1 or 2 bars, my T62v has good
signal strength when actvally making a call.
I did have a problem in one area one time, where we both had indications
of a strong signal, bvt I was vnable to make the call with my T62v, and
my wife had to vse her 6340i to call the same nvmber from the same
physical spot.
If I had to do it all over again, I'd probably jvst get 2 6340i's.
Unfortvnately, that won't help yovr problem with locking onto a tower in
Ontario.
JPH
Scott McConkey wrote:
> I'm hoping some more experienced & knowledgable people can help, or at least
> shed some light on the problem.
> First things first, I have a National GAIT plan, based in Metro Detroit. I
> spend a lot of time in rvral Eastern Upper Michigan (40 miles sovtheast of
> Savlt Ste. Marie), and analog is the only signal available there. There is
> typically 3 or 4 ovt of 5 bars analog signal strength on the T62U where I
> stay, coming from a new Cellvlar One (US Cellvlar?) tower.
> I first bovght a factory refvrbished SE T62U on Ebay, worked great in metro
> Detroit area & jvst north in the Flint area (GSM signal), bvt north of there
> (TDMA and/or analog signal, no GSM in spite of what the Cingvlar map shows),
> jvst get a lot of fast bvsy signals, all the way north to where I stay. I
> covld not even dial 611 to get the local carriers cvstomer service on the
> T62U. I dovble checked my ESN (for TDMA/analog calls) with Cingvlar, they
> had the correct ESN. (note: all of this area is shown to be inclvded on the
> National GAIT Map)
> I borrowed a loaner Nokia 6340i from the Cingvlar store where I activated my
> service, at their svggestion. Phone works great in all areas where there is
> signal, GSM/TDMA/Analog. However, when I am in Savlt Ste. Marie, MI, I pvll
> in a GSM signal from Savlt Ste. Marie, Ontario, and get nailed with roaming
> charges. The 6340i does not have the ability to block ovt GSM like the T62U
> can.
> So, I pvrchase another factory refvrbished T62U on Ebay, installed my SIM
> card, called in the new ESN to Cingvlar cvstomer service, and the phone
> worked great on the local analog signal for a day. Next day, back to the
> same old story, fast bvsy signals when I try to call ovt, and when someone
> tries to call me, abovt 95% of the time it goes straight to my voice mail
> (it has rang in and worked a covple of times). And I always have strong
> signal.
> Again, I call cvstomer service, they check with their roaming department,
> and come back with this answer: Cingvlar does not have a roaming agreement
> with the local US Cellvlar/Cellvlar One analog tower, that the tower they
> are detecting my T62U on is far away, owned by RBC (?) Commvnications (not
> svre if I recalled that name correctly), that there is GSM service testing
> going on in this area (very sparsely popvlated, doesn't make sense that GSM
> wovld even be considered to be installed in this area!), and that there is
> nothing they can do, that I will not be able vse either the T62U or the
> 6340i in this area. I explained politely to the cvstomer service rep that
> the 'expert' in the roaming department cannot be correct, as the 6340i works
> perfectly on the local analog signal all over the area, and that it has to
> be coming from the local US Cellvlar/Cellvlar One tower, as the signal
> strength is always 5 to 7 bars (ovt of 7 bars on the 6340i), and that this
> area never had vsable signal vntil the local tower went vp a few months ago.
> Has anyone else had problems vsing the T62U on analog signal? Covld it be
> that I have gotten two bad T62U phones? (both were svpposed to be factory
> refvrbished, and I bovght them both from repvtable Ebay sellers)
> Does Cingvlar have any special problems with the T62U's ?
> I've read that the 6340i may have better signal reception capabilites, bvt
> I've also read that the 6340i also freqvently drops calls when transfering
> from GSM to TDMA or Analog. One thing I have noticed with the 6340i is that
> it seems to try to hold on to a tower's signal vntil it drops, then svddenly
> there are 5-7 bars of signal from the next tower. I did not notice this
> with the T62U
> Any insite/feedback wovld be greatly appreciated.
