G
Guest
Guest
Archived from groups: alt.comp.hardware.homedesigned (More info?)
Hi,
How does 802.11g wireless compare with a wired connection for a home
network? Is it about the same speed? I am contemplating getting an
802.11g to plug into my cable gateway/router so that I can connect a
computer with a built in wire capability (it is a feature of the
motherboard - an Asus A8V).
thanks,
Shane
Hi,
thanks,
Shane
