Advice on power supply desired
Archived from groups: alt.comp.hardware.homedesigned (More info?)
Guys,
First off I have to order a power supply in the next few days. I need
advice on what to order. Price is a concern, but I am willing to spend up
to $200 shipping and tax included, if there is shipping or tax.
I am looking at this supply,
http://www.maxpoint.com/products/pow_supp/spec_pg/noistakerax2/index.htm#
The Enermax Noisetaker AX 2.0. It offers excellent specs, even the ripple
on the 12V #1 rail is very low so that the CPU/RAM get a clean source for
better overclocking etc.
My system specs will be these:
Asus A8V (later on I may end up getting a SLI motherboard)
1 up to 2 Gig (2 to 4 sticks of RAM) in Dual Channel mode. Possibly either
Patriot or OCZ TCCD RAM
A Sapphire 9600 Pro vid card (will be a better card later on obviously)
Up to 6 hard drives (Important to me) 4 in SATA two in PATA.
1 DVD Burner
1 CD Burner
Several fans, 1 CPU, 3 to 5 Case fans run at lower speeds via fan control
for quietness but improved air flow (1 top blow hole, 1 or 2 rear, 1 facing
CPU/Video card(s) 1 to 2 in front of case, depending upon the case, I want
to keep the hard drives cool, they get hot).
2 Cold Cathode lamps (I have them, so I might as well use them).
Added Sound Card with Live! Drive.
Case will be a full tower until I build my "hand made from scratch case" in
a year or so.
So... I want a Power Supply that will support a high performance AGP video
card for now, but will support a PCI Express SLI setup later, and all of
the above specs. I have calculated that it would be best to get a good
strong 600Watter at least, since I will be eventually running a lot of hard
drives as I accumulate them.
If there is a case comperable to this Enermax case for a lower price let me
know, and no matter what, I'd love some opinions on what cases you all
like, where to get them, and what *you* use.
2 answers Last reply
More about advice power supply desired
  1. Archived from groups: alt.comp.hardware.homedesigned (More info?)
    "signmeuptoo" <signmeuptoo_no_spam@earthlink.net> wrote in message
    news:7vlwqo34i9eq.1i2n570z30299.dlg@40tude.net...
    > Guys,
    If you are going to get an SLI board later, you will probably need the new
    24-pin power plug to the mobo.. if I recall right, the Antec Neopower has
    both the 20 and 24-pin connectors.
    http://www.newegg.com/app/ViewProductDesc.asp?description=17-103-924&depa=1
  2. Archived from groups: alt.comp.hardware.homedesigned (More info?)
    signmeuptoo wrote:
    > Guys,
    the specs on the 12v #1 & 12v #2 are 18a each, combined 35a.
    is this good or misleading?
Homebuilt Power Supplies Systems
