Too many pins on power supply. 20 / 24
Archived from groups: alt.comp.hardware.homedesigned (More info?)
Hello,
You have 24 pins on your power supply unit and a 20 pin connector on
you motherboard. Simply snap off the extra four pins. The connector
should separate easliy.
See: http://www.antec.com/pdf/manuals/SmartPower2_En.pdf
Good luck,
David McRae
www.datanetzs.com
1 answer Last reply
More about pins power supply
  1. Archived from groups: alt.comp.hardware.homedesigned (More info?)
    David_Mac_McRae@DataNetzs.com wrote:
    > Hello,
    > Good luck,
    > David McRae
    > www.datanetzs.com
    Or you can buy an Enermax 'all in one'. They're the ginchiest.
    Bryan (testing)
Homebuilt Hardware Power Supplies Motherboards Systems
