Archived from groups: microsoft.public.pocketpc (More info?)
My 30 day old 4150 works perfectly on all counts except till 48 hrs
back when the battery doesn't charge & the LED does not come on - it
just says Main battery is on " AC Power" with no indicator for
charging . Backup Battery shows 100%.I have tried :
1. Directly charging with mains for over 24 hrs
2. Several soft resets
3. Removing and physically replacing the battery
4. Connecting with HP website for diagnostics - it doesn't recognise
the battery
5. Talking to HP chat - they say go to a service centre
6. Even uninstalling Battery Plus software - in case of any glitch
Please help before my last resort of going to a service centre.
Many Thanks,
Ranjit
"Ranjit" <ranjitshah@gmail.com> wrote in message
news:a930e843.0408082351.bcb0f71@posting.google.com...
except till 48 hrs
indicator for
tried :
> the battery
centre
case of any glitch
service centre.
> Many Thanks,
> Ranjit
it sounds like bad battery connections, can you
'wipe' the contacts on the battery & inside the
battery compartment?
roy
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system
(http://www.grisoft.com).
Version: 6.0.734 / Virus Database: 488 - Release
Date: 04-Aug-04
"Roy Collingwood" <roy@roycollingwood.co.uk> wrote in message news:<WbOdnf7hFZlNyIrcRVn-tA@brightview.com>...
> except till 48 hrs
> indicator for
> tried :
> > the battery
> centre
> case of any glitch
> service centre.
> > Many Thanks,
> > Ranjit
> roy
> Date: 04-Aug-04
Thanks - tried it but it didn't work.The battery seems fine since I
can charge it separately (outside the 4150) and the amber light turns
to green in a reasonable time on the charger.Also I tried a hard reset
but no change. Any other thoughts - Thanks.
Ranjit,
Not sure what the battery contacts look like on the h4150, I have one on
order so should know soon.
If they are small pins like on some devices they could be stuck and
therefore not making a good contact with the battery contacts. I had a
phone like that once that required the pins to be set free so it would make
a good contact.
Just an idea.
Graham
news:a930e843.0408090546.cd7c795@posting.google.com...
> > except till 48 hrs
> > indicator for
> > tried :
> > > the battery
> > centre
> > case of any glitch
> > service centre.
> > > Many Thanks,
> > > Ranjit
> > roy
> > Date: 04-Aug-04
That happened to me too - I had the battery in upside down (yes it will
fit)....
> the battery
> Many Thanks,
> Ranjit
Can't you just exchange it where you bought it? Sounds lije a hardware
issue!
=== Posted with Qusnetsoft NewsReader 2.2.0.8
----- Original Message -----
From: "Graham Tavener" <graham.tavener@gmx.net> Sent: Mon, 09 Aug 2004 16:
25:16 Subject: Re: Newly purchased IPAQ 4150 battery not charging & LED
does not come on
Ranjit,
order so should know soon. If they are small pins like on some devices they
could be stuck and therefore not making a good contact with the battery
contacts. I had a phone like that once that required the pins to be set
free so it would make a good contact.
Just an idea.
Graham
"Ranjit" <ranjitshah@gmail.com> wrote in message news:a930e843.0408090546.
>> except till 48 hrs
>> indicator for
>> tried :
>>> the battery
>> centre
>> case of any glitch
>> service centre.
>>> Many Thanks,
>>> Ranjit
>> it sounds like bad battery connections, can you 'wipe' the contacts on
>> the battery & inside the battery compartment?
>> roy
>> Outgoing mail is certified Virus Free. Checked by AVG anti-virus system
>> (http://www.grisoft.com). Version: 6.0.734 / Virus Database: 488 -
>> Release Date: 04-Aug-04
> Thanks - tried it but it didn't work.The battery seems fine since I can
> charge it separately (outside the 4150) and the amber light turns to
> green in a reasonable time on the charger.Also I tried a hard reset but
Thanks, all:
I cleaned the battery tips and did everything that was recommended -
then I left it to charge for 48 hours untouched and suddenly the LED
showed that the battery was "alive & kicking". I can't explain it but
I'm glad it has restarted and no further glitches till now. Ranjit
