G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
I have a problem to understand what is the relation between FSB and
BUS speed and Memory speed??
1)What is FSB? is it a physical bus? is it in the motherboard?? if
yes, why CPU manufacturing company say for example AMD 2.4 with FSB
133 Mhz, does that mean FSB is part of the CPU architecture?? IF yes
it is part of the CPU, should FSB match the BUS speed of the mother
board to get fast computer??
2) What does the BUS speed mean?? does it mean the speed of the
motherboard buses?? does it have any relation with FSB??
3) How about Memory rate or speed?? does that mean the speed of the
bus inside the memory in other words, the speed that is used to
transfer data inside the memory? How this speed related to FSB or BUS
speed??
Any help would be very much appreciated. Thanks
speed??
