Archived from groups: alt.comp.hardware.pc-homebuilt (
More info?)
On Sat, 10 Apr 2004 00:08:55 GMT, kurt_SPAMLESS@hotmail.com (Overlord) wrote:
>On Tue, 06 Apr 2004 22:34:35 GMT, Patrick <pberry26@yahoo.com> wrote:
>>All of my 10/100 NICs are hooked to 10/100 Mb router/switches, and I'm
>>just plain thrilled to get 384Kilo bits/second out of Bright House!
>>They have switched to fiber optics most of the way, (Orlando, Tampa) and
>>opened up the bandwidth a bit. Yes, that is BOTH WAYS, up and down -loads!
>>So come and get your Knoppix, Stux, freeduc, and other, fast LiveCDrom
>>ISOs on Limewire, because, I am serving off of two Cheetah 10,000 rpm
>>drives!!! search words 'Linux'
>>Now, on internal network data transfers, the speed MIGHT go up a bit,
>>but, most hard drives on the IDE buss in your computers are limited to
>>about 12Mb per second (on a GOOD day!). Those SCSI Cheetah 10,000 rpm
>>drives have a theoretical limit of 160 Mb/s. As installed it might hit
>>20 to 40 Mb/s, but, I doubt it.
>>Yeah, Serial ATA drives purport to go about 180Mb/s, but, I think I will
>>stick to SCSI for the multi read/writes they can do...
>Yeah, if you're serving, depending on the traffic, I'd stick with the SCSIs and their
>I/O queing<sp?>. I've got a handfull of 10k's; Cheetahs, Fujitsu, and uh.... WD.
>For the OS drive and a few other prog drives I run 15k's. I find they're a lot quieter
>than the 10k's but run hotter. I've benched the 10k's before but don't remember
>the specific numbers that came up. Depending on the model, you might hit 60MB/s
>or close to it from a single drive which is 480Mb/s. But you're still only pushing
>3/8 of a MB/s down the wire.
>What's Bright House, DSL? Go with the cable. My Cox gets 29xxMb/s DL after
Oop, should be 29xxKb/s or 2.9xxMb/s
>TCP/IP tweaking. I can get some files on Limewire at a steady 1200Mb/s depending,
and should be 1.2Mb/s or 1200Kb/s
>of course, on the source. I've pulled Knoppix ISO's from some university in FL at 350Kb/s
>but then I've FTP'd it from England and Germany at that.
>Still looking for the new Knoppix that'll write to NTFS drives....
Bait for spammers:
root@localhost
postmaster@localhost
admin@localhost
abuse@localhost
postmaster@[127.0.0.1]
uce@ftc.gov
Remove "spamless" to email me.
