Cooling for a "new old" quiet system
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Hi,
I'm resurrecting an old KT7E, this time with a Duron 1.2 CPU, with 768MB of
PC133 memory.
The KT7E has a small HSF on the Northbridge, and this fan is really noisy.
It's louder than both the CPU HSF and the power supply it seems.
I'm thinking of replacing that Northbridge HSF with the blue Zalman
Northbridge cooler, and am looking for comments re. the Zalman (the
Northbridge cooler).
Right now, for the CPU, I'm using a stock AMD HSF that I borrowed from a
friend, just to get things working. One of my goals with this machine is to
try to get it as quiet as I can, and I've been experimenting with lowering
the Vcore (which the KT7E BIOS makes very easy to do). So far, I'm down to
1.40v on the Vcore, and the CPU temp is running at 42C in the BIOS display,
at speed 1200 (100).
I'm wondering, if I keep that Vcore, and lower the speed to, say, 900, would
I be able to safely run this CPU without the fan on the HSF? Or, maybe is
there another heatsink that would do a job at passively cooling this CPU?
Another possibility is a quieter HSF that would do a reasonable job. I'm
looking at the TR2-M1. Reviews seem good, and it seems pretty quiet with a
lower speed 80mm fan (the AMD fan runs at ~4200 rpm).
I know this is a bit unusual (most folks want to overclock), but as I
mentioned, I'd really like to get this machine as quiet as possible.
Thanks,
Jim
8 answers Last reply
More about cooling quiet system
  1. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    First, before going any further, I'd suggest running Prime95 on that lower
    vCore, just to see how stable it really is. The fact it boots, or even
    loads Windows doesn't mean all that much. It will drive you nuts later on
    if the system constantly remains unstable while undervolted. I had a
    problem on my Abit VI7 because the BIOS is unfortunately undervolting the
    CPU (as low as 1.42v at times, usually 1.45v), the thing seems fine
    initially, but lots of strange things start happening unless I manually
    overvolt.
    As far as undervolting to keep temps down, that's not going to be enough to
    save you from using a fan, or water cooling, or something. Perhaps the ONLY
    thing that might help is a Zalman, they have several VERY large cooper
    heatsink solutions. The "flower" type heatsink *may* be able to get by
    without a fan under limited conditions, but even a little fanning makes a
    big difference. Lower ambient temps help too. The flower type comes w/ a
    large 92mm fan (mounted to the PCI slot!) that turns more slowly than a
    common 80mm fan, and it's the fan blades that make most of the noise. The
    bigger the fan, the slower you can run it for the same CFMs. But going with
    NO fan, that's pretty tough, esp. w/ AMD. Their thermal control is terrible
    to begin with, that's why the core is exposed! You stand a lot better
    chance of running "silent" w/ Intel.
    Personally, I think undervolting vCore is a waste of time. As long as the
    CPU temps stay within specs, and within reason, far too much is made of it.
    Too many people are making extraordinary efforts to keep under 50C (load),
    when it's perfectly safe to run as high as 60C. I'd rather run HOTTER than
    NOISER! The processor is spec'd to something like 90C (if I recall). And
    while I would never let it run THAT hot, I'd still provide some safety
    margin, running 55-60C is perfectly fine, well within spec, esp. if not
    OC'ing. So what's the point of undervolting?! Keep it stock, get a big
    honkin' cooper heatsink w/ lapped bottom, good thermal paste, and LARGE,
    slow turning fan (add a speed controller if you like), and it should be fine
    *and* quiet. The only guys who have the real problems w/ silence are the
    OC'ers. They need the extreme lower temps to make OC'ing possible. For
    mere mortals, the temps are not really something to be overly concerned
    about, as long as within spec.
    HTH
    Jim
    "Ohaya" <Ohaya@NO_SPAM.cox.net> wrote in message
    news:CHRec.6863$55.5304@lakeread02...
    > Hi,
    of
    > PC133 memory.
    to
    to
    display,
    would
    a
    > Thanks,
    > Jim
  2. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    "Ohaya" <Ohaya@NO_SPAM.cox.net> wrote in message news:<CHRec.6863$55.5304@lakeread02>...
    > PC133 memory.
    I don't know the answers myself, but I know where you'll find
    plenty of people who do:
    http://www.silentpcreview.com/
    Take a look at the forums and ask your question there. You'll
    find plenty of people who have undervolted and underclocked
    their way to silence.
    Isaac Kuo
  3. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    "Jim" <null@null.com> wrote in message news:aPTec.1695$Yf6.413@fed1read07...
    > overvolt.
    to
    ONLY
    with
    terrible
    it.
    than
    fine
    > HTH
    Jim,
    Thanks for the comments. I'll be sure to run Prime95 as soon as I get the
    chance...
  4. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    I think it's unlikely that you can go totally passive on your CPU. A
    better heatsink sporting an undervolted 80mm Panaflo L1A fan should be
    so quiet that it should be almost inaudible.
    If you haven't already visited http://www.silentpcreview.com/ , I
    suggest you do so. Be sure to visit the forums, there is a treasure
    trove of information there on the kind of issues you are exploring (e.g.
    undervolting and underclocking).
    > Hi,
    768MB of
    > PC133 memory.
    noisy.
    a
    is to
    lowering
    down to
    display,
    would
    maybe is
    CPU?
    I'm
    with a
    > Thanks,
    > Jim
  5. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    "Biff" <Biff@spamhaters.org> wrote in message
    news:I4Uec.8086$A_4.1888@newsread1.news.pas.earthlink.net...
    Biff,
    Thanks. I'll keep you comments in mind, and BTW, have already spent a lot
    of time on that site :)...
  6. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    news:ZzUec.6870$55.6550@lakeread02...
    lower
    on
    the
    > > overvolt.
    > to
    > ONLY
    a
    a
    The
    > with
    > terrible
    the
    > it.
    (load),
    > than
    And
    > fine
    the
    > > HTH
    > Jim,
    > chance...
    Hi,
    Well, I got everything loaded up. I ran Prime95 for about 20 minutes, using
    the Abit/Via hardware monitor, and am getting to about 45C. This is still
    with Vcore at 1.40v!
    Jim
  7. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    So take it off. It isn't needed. Put a large passive HS on it if you like.
    Havn't seen it, but it'll work. As would any other.
    > is to try to get it as quiet as I can, and I've been experimenting with
    > lowering the Vcore (which the KT7E BIOS makes very easy to do). So far,
    > I'm down to 1.40v on the Vcore, and the CPU temp is running at 42C in
    > the BIOS display, at speed 1200 (100).
    > would I be able to safely run this CPU without the fan on the HSF? Or,
    > maybe is there another heatsink that would do a job at passively cooling
    > this CPU?
    > with a lower speed 80mm fan (the AMD fan runs at ~4200 rpm).
    The TR2-M1 (M3 without lights) will work well for any cpu you use. Put a
    speed control on it and you would even be able to hear it, if you can now.
    Unless you run your system at 100% for long periods of time you don't even
    need a fan on the cpu if you use softeware cooling, like Vcool. Running
    LVcool (Linux version) on an athlon XP Palomino core over clocked to
    1750MHz and overvolted to 1.85v (the hottest I could make it) idle temp
    was only 28.8C with the TR2-M3 cooler and case temp of 26.5C. Under full
    load, it climbed to 47C. Now that was with the stock fan running. Without
    the fan, idle temp went up only about 2C. Your PSU fan will probably drown
    out the TR2-M1 cooler fan anyway. With your Duron not overclocked and
    undervolted, it won't put out half the heat as the one I used for testing.
    Abit KT7-Raid (KT133) Tbred B core CPU @2400MHz (24x100FSB)
    http://mysite.verizon.net/res0exft/cpu.htm
  8. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    Ohaya wrote:
    > Hi,
    > of PC133 memory.
    > lowering
    > to 1.40v on the Vcore, and the CPU temp is running at 42C in the BIOS
    I agree with the others, don't undervolt unless you also are going to
    underclock. As far as quiet, get a BIG zalman flower for a faster cpu and
    gently move some air across it and it should be fine. I'm using an XP2000
    rated HS on a P3-800 passive cooled with a hole in the side of the PSU to
    pull some air across it and it's fine. I even used a 47 ohm 1 watt resistor
    to tone down the PSU.
    And no I'm not 3d gaming nor plan to run 100% load benchmarks to see how hot
    I can get it as it will never see that kinda stress in the real use that
    box sees.
    Stacey
Homebuilt Cooling CPUs Systems
