some bus speed questions
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Hi
I am reading different articals about the bus speed.. and I came to
some points that I do not understand, could you please help me.. these
are the points I do not understand
1) <quote> FSB speed setting is determind by the CPU </quote>
My question what does that mean?? does it mean CPU decide the speed of
the FSB?? is not true that FSB has its own clock and that clock decide
the speed of the FSB?
2) Does the CPU has an internal clock or it uses the FSB clock
(external clock) + the multipler to generate what is called internal
clock??
3) OverClock, does that term mean is to increase the FSB speed?? would
that effect the momory bus speed??
I would appreciate your help in advanced..
3 answers Last reply
More about some speed questions
  1. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    On Tue, 13 Apr 2004 08:20:20 -0700, esara wrote:
    > Hi
    The FSB speed (clock) is generated by the MB. Most MB allow you to et this
    either in the bios, by a jumper on the MB, or both. Very few MB's may not
    have a setting and will use what's defined as default by the FSB sense
    pins of the cpu. So basically, the quote is only refering to MB's that
    don't support a FSB setting.
    > 2) Does the CPU has an internal clock or it uses the FSB clock (external
    > clock) + the multipler to generate what is called internal clock??
    It uses the FSB clock x multiplier for cpu clockspeed.
    Overclock generally means running the CPu faster than it's rated speed.
    This can be accomplished by raising the FSB speed, raising the multiplier,
    or both. Personally, I don't really consider a cpu overclocked until I go
    over the the maximum rated speed for the core, not the model.
    As for the memory bus, it depends on the MB. Some allow async operations
    and some don't. Most newer boards do I believe. The one catch is that
    while you can set the mem bus speed seperately, it may increase too if you
    set the FSB to an in between value. IOW's, my FSB set to 180 and mem bus
    set to 166 will run the mem bus at 180. My FSB set to 200 and mem bus set
    to 166 will run the me bus at 166. 201=167, etc.
    Abit KT7-Raid (KT133) Tbred B core CPU @2400MHz (24x100FSB)
    http://mysite.verizon.net/res0exft/cpu.htm
  2. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    FSB Speed is a little tricky. Take a Athlon 2400+ as an example. The
    FSB speed is 266Mhz. However the actually clock speed generated by
    the clock generator on the motherboard should be set to 133Mhz. AMD
    motherboards and especially the AMD processor have 2 Actions performed
    for every clock cycle. Because of this, The FSB is 2 X 133 = 266.
    How this is done on a P4 Processor is different than on an AMD
    processor. This is because both the AMD and the Intel processors
    produce the same results, but they do this using a different
    Architecture or chip design. The 800Mhz FSB on a P4 is achieved at a
    200mhz clock but it is quad pumped.
    Therefore the FSB is 4 X 200 = 800.
    >Hi
    >clock??
  3. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    Leave it to the government to only get it half right.:-)
    Bus speeds are measured by the clock rate in Hz.
    Data rates are measured in throughput using bps or Bps.
    You are taking the 400/800 data rates and giving them a bus speed MHz
    rating which is just wrong.
    A ddr (K7) bus of 200MHz has a data rate of 400Mbps per line, or a
    thoughput speed of approx. 3200MBps assuming a 64 bit wide bus. And qdr
    (P4) would be 6400MBps.
    See The Real Front side Bus in link below.
Homebuilt CPUs Bus Speed Systems
