Synchronization of buses speed
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Does synchronization makes the computer faster. I mean if I make the
speed of the FSB running at speed similar to the memory speed. For
example if I have DDR200 then I will make sure I will have a CPU with
FSB 400 and the motherboard should support FSB 400. Is this the
ulitmate goal of a computer designer in term of the speed?? or
Synchromization is not important??
Any help would be appreciate it .. thanks..
2 answers Last reply
More about synchronization buses speed
  1. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    You want the data rate to match the FSB speed for best performance, With
    DDR ram that means running them in sync. With non DDR (PC100/133/150) ram
    and a a DDR FSB, you want the ram running as fast as possible.
    Abit KT7-Raid (KT133) Tbred B core CPU @2400MHz (24x100FSB)
    http://mysite.verizon.net/res0exft/cpu.htm
  2. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    Even this doesn't seem to help. I tried this with a 1Ghz Duron and ran
    the memory at 133Mhz and it actually benchmarked slower than when the
    memory was running at 100Mhz.
Homebuilt Computer Systems
