Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Hello:
I have a WD 80GB hard drive in my computer at the moment and I'm
running out of room on it. This drive has 2 partitions on it.
I'd like to buy a new and much bigger HD (definitely another WD) and
would like to be able to copy or transfer all the data from the old HD
to the new drive. I mean OS and all. Is it possible? If yes, is there
an easy to do this?
My computer is 3 years old - AMD Athalon 1.2 GHz with 512MB memory.
Running WinXP and WinME (dual boot)
There is a program "Norton Ghost" that does this. It would copy the HDD
exactly onto the new one, except it would allow you to resize. Where to get
it, I dunno. I think it comes with systemworks, a nice lil package to have
anyhow.
--Don
"Lucky Dog" <luckydog@home.com> wrote in message
news:rpru70d1if4biktgqum04ufahcv677uhdg@4ax.com...
> Hello:
> an easy to do this?
> Thanks in advance for any suggestions!
Lucky Dog said this...
> Hello:
> an easy to do this?
Check out the WD support site. I believe they have a free tool available to
do a full copy as you require.
"Donald McMorris - Ospitare International" <newsalias@ospitare.net>
wrote in news:YzLfc.58057$M3.19344@twister.nyroc.rr.com:
> HDD exactly onto the new one, except it would allow you to resize.
> Where to get it, I dunno. I think it comes with systemworks, a nice
> lil package to have anyhow.
> --Don
>> Hello:
>> HD to the new drive. I mean OS and all. Is it possible? If yes, is
>> there an easy to do this?
I just used Norton Ghost 2002 (part of Norton System Works 2002) to do
exactly that. Created an image of the partition to cdrs & restored back
onto the new drive. Check around - you can probably pick up an old copy
of NSW 2002 for a couple of bucks now.
Thanks to Donald, Groove and Tmana for your help. I really appreciate
the time you took to reply to me. :-)
>> --Don
>>> Hello:
>Tom
