Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
This Seems to be the place for sensible answers....
I recently built the following:
ASUS A7V8X-X
ATHLON XP3200+
512MB (PC3200)
MX4000 GFX card
Samsung 40gig H/D
Running from a 400w PSU
The temperature rarely rises above 45oC -CPU and 35oC M/Board.
I installed windows XP and it ran for an hour before crashing and coming up
with the following error message:
"Windows could not start because the following file is missing or coirrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
then tells me I can repair this using the original XP cd-rom.
I`ve done this twice and ended up re-installing on both occassions, still no
use it runs for a while then crashes to same error message.
I have tried it with different Hard drive (IBM Deskstar) with XP already
installed and it ran fine for a few days non-stop.
I then attached the Samsung drive again as slave and tried to format it from
within XP.
System crashed, now IBM hard drive is showing the sam error.
It`s driving me insane, is it something blindingly obvious or is there a
hardware fault somewhere?
Cheers
Pete
ASUS A7V8X-X
ATHLON XP3200+
512MB (PC3200)
MX4000 GFX card
Samsung 40gig H/D
within XP.
Cheers
Pete
