G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
I wonder if anyone can give me some tips to help trace a problem I am
having.
I recently upgraded my self-built system by changing the motherboard,
memory and video card. I had previously upgraded the hard drive and
various other bits and pieces.
At first everything worked fine, but after a couple of weeks the
entire system died. Checks revealed that the PSU had died. I carefully
checked everything in the system for short circuits, bad connections,
etc, etc, but all was fine. The computer shop I used suggested that
the new components had possibly placed too much demand on an old and
low-powered PSU.
I then bought a good quality 400W PSU, checked everything out, and it
all worked without any problems. I reassembled the system, and it
still worked without any problems.
After about two months, I left the computer running overnight going
through various utilities. By morning... dead again.
I am baffled by this. If it was a short circuit, the PSU would have
died immediately (wouldn't it???).
I don't think the problem lies with the HDD, CD-ROM, modem, etc, as
these all worked fine with the old motherboard for a long time.
So the culprit must be (I assume):
- the motherboard
- the PSU
- the new video card
- the memory
Does anyone have any ideas about what sort of problem would cause a
power supply to blow after two months of trouble free operation? I
don't want this problem to recur, and I don't particularly want to
have to replace all the components, either.
Any suggestions either as to the cause of the problem, or as to how I
might try and track it down would be appreciated.
Many thanks.
Graham D
having.
low-powered PSU.
- the motherboard
- the PSU
- the memory
Many thanks.
Graham D
