Archived from groups: alt.comp.hardware.pc-homebuilt (
More info?)
It isn't difficult to install.
The amount of noise produced is dependent on the size and speed
of the fan, and, indirectly, the size of the radiator.
You can use a large radiator, from a motorcycle or one made specifically
for the task, and get away with not even using the fan, except for under
heavy load, producing a nearly inaudible system. Or, you can use a few,
larger fans running slowly, which would lower noise. It is also possible to
run
the waterlines to a radiator that is in a different room or basement,
producing
no audible noise in the computers' room.
Dave
"the gnome" <the_gnome@at.copperstream.co.uk> wrote in message
news:1084809300.390444@smtp-1.griffin.com...
> Is it difficult to install on a new build, and how quiet is it ?
> the_gnome
