Using a P4 with 400mHz FSB on a 533 mHz M/B
G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
hi all
I currently own a P4 1.7 Northwood 512 kb cache, with 512 SDR Ram, the
M/B has a FSB of 400mHz.
I 'd like to upgrade my system by getting a M/B that will support DDR
Ram, but i'd like to keep my P4 1.7 for now. If I buy a 533mHz or 800
mHz M/B will my processor be compatible? Might it be possible to
overclock it using the 533 setting to 2.26 gig (ie 133mHz x 17 = 2.26
instead of 100 mHz x 17 = 1.7 mHz) or have I got the wrong end of the
stick?
thanks for looking
Gaz
G
Guest
Guest
"Gaz" <gazoc7@aol.com> wrote in message
news:93c86c54.0405212030.7332a283@posting.google.com...
> hi all
> stick?
Yes, you can re-use your 100/400MHz P4 1.7GHz CPU
at100MHz on most 533MHz/800MHz boards. We are a dealer
and can sell you one.
Thanks.
Kevin Chalker, Owner KC COMPUTERS
E-mail: kc@kc-computers.com Web: www.kc-computers.com
Internet dealer for 13+ years!!! See WWW.RESELLERRATINGS.COM!!!
