G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
If I got the right dope from the net, pin 8 on an ATX power supply
is supposed to read +5 vdc if the PS's output voltages are within
specs, and drop to zero if they aren't.
I have one on the bench now and pin 8 is low, but all the other
pins read what they shuld.
My question is, do they always read low if you have them out
of a system sitting on a bench with pins 13 and 14 jumped?
or do you have to test them installed?
Thanks,
Al
Thanks,
Al
