Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Anyone have an idea to troubleshoot this problem?
Friend's pc using Netgear USB nic (ma111) stopped connecting with the
Netgear wireless router. Other pcs with a wireless connection to the
router work. This pc's nic is working properly according to WinMe, WEP
encrytion is enabled, pass code is correct but the pc still doesn't
connect to the router to obtain a DHCP address or by using a static ip
address. This WinMe pc was working properly but it stopped connecting
over the weekend.
TIA
over the weekend.
TIA
