Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > balloon message and wireless connection problems pls help
Archived from groups: microsoft.public.windows.networking.wireless (More info?)
i have a home network with 2 pcs Sony Vaio and a dell laptop my 2 pcs are
connected to the wireless router and the laptop has a wireless card. this is
what is happening every other day when i turn my computers on i will see the
connection coming in, but when i open the browser to access a page it will
not display the page. i go into the router setup page and reset everything
again and still will not work so what i have to do is unplug the router wait
a minute and plug it back in and it will start working. also i get the pop up
balloon saying local area connection
a local cable network is unplug i get this like every 1/2 hour and is i'm
using a messenger lik msn or yahoo it will sing me out and sing me back in
within 30 seconds pls any help if got this far pls i need all the help i can
get cause it's getting very old to unplug the router everytime that happens
Sponsored Links
i also forgot to mention that i have a wireless router CNet cwr-854
Reply to Roger
Hello , right click on wireless icon /Open network connections / right click
local area connection / disable . And if you have '1394 Connection' , enable
1394 . And same with 'Wireless Network Connection ' enable . With SP2 , Rigt
click on either icon / Properties / Advanced / Windows Firewall ' / click
'Settings' button / Turn on Firewall if you want . A Padlock will appear on
all 'enabled' connections . For browser connection : Try right click on ISP
icon / Connections / Connection Settings / LAN . I had browser problems
periodicaly , and when I diabled 'Cable' connection and seleted 'LAN'
connection , all is well . Also , click 'Make Default' button after selecting
'LAN" . You may need to call the wireless company and go through your other
settings with them . I setup my wireless and found it was worth the while to
call the wireless company for getting the proper and effective settings .
Your SSID may be set to your own settings ,and then make that SSID (default)
in ' View Available Network Connections ' Right click on Wireless icon .
KD
Reply to Installer
- 0 +
hello KD tks for ur help, i'm not quite sure if i got it right yet but this
is what i see when i open my network connections :
Internet Gateway
Internet Connection
Connecting
Internet Conection
LAN or High-Speed Internet
1394 Conection
Connected, Firewalled
1394 Net Adapter
Local Area Connection
Realtek RTL8139 Family PCI F...
if i disble the local area connection i can't connect to the internet
can u pls guide trough the process if it's not to much to ask maybe from the
begining. to see if i did something wrong.
tks so much again for ur help
> KD
Reply to Roger
Hello , Sounds as if your SSID's are not matched or same .( I believe you
have your Cable Modem connected to the wireless router , and the pc connected
to the wireless router , and local connection is good . To set SSID will be
in two areas . 1) in 'View Avaiable Wireless Networks / Change the order of
preferred networks / Check 'Use Windows to configure my wireless network
settings / in ' Preferred networks ' these are the preset SSID's 1 or more
will be listed . 'Automatic' , 'On Demand' and 'default' will selected after
you click 'Add' button ,Click 'Add' / click 'OK' / you may type in your SSID
.. in (SSID) box on the 'Wireless network properties' window . Next , is
wireless network key : Network Authenication : Open / Data encryption : WEP .
/ Check 'The key is provided for me automaticaly . / Click 'OK' . / 'Wireless
Networks ' sould be open still , and click to highlight the SSID / 'Move up
' button . This will make you SSID the default after you set up at the
wireless website settings page . 2)Go there and view all tabs and familiarize
with the tabs , find match up SSID characters . In 'Security' / Wireless /
You may select your own WEP key there or write down and save the one perhaps
provided and should only be in 'Key 1 : Use 1 key , do not use the
'Passphrase:' make that box blank / Securoty Mode : WEP / Default Transmit
Key , tic 1 / WEP Encryption : try 64 bits 10 hex digits ... this will mean
you will use 10 letters and numbers total . for the WEP Key / Key 2 , Key 3 ,
Key 4 will be left blank / Click 'Save Setting ' button . Click 'Wireless
Settings ' tab / Basic Wireless Settings / Wireless Network Mode : Mixed /
SSID : your choice as to match exactly per settings in Preferred Networks' /
Wireless Channel : 11 - 2.462GHz / Wireless SSID Broadcast : Enable , but be
sure to contact the wireless people to understand this setting , to determine
security and eavesdropping . Select 'Save Settings . ' In 'Setup ' tab
Router Name is required / Host name leave blank / Domain Name blank / MTU:
Auto / The rest is default . Click 'Save settings ' Minumize this website for
now . Right Click wireless icon / View available Wireless Networks / You
should see your SSID in the big box . / Highlight the network you want to
disconnect before connecting to your new SSID . After hightlighting click
'Disconnect' / Click on the new SSID to hightlight / click Connect . You must
disconnect 'Local' after recieving the Wireless connection stastus and then
you will not see that balloon . Remove Cable from pc to router .
KD
> Internet Gateway
> Internet Connection
> Connecting
> Internet Conection
> 1394 Conection
> 1394 Net Adapter
> > KD
Reply to Installer
- 0 +
ok KD tks again i'm going to follow the instructions thank u much for your
help hopefully this will work, i will keep u posted
> KD
> > Internet Gateway
> > Internet Connection
> > Connecting
> > Internet Conection
> > 1394 Conection
> > 1394 Net Adapter
> > > KD
Reply to Roger
- 0 +
also i forgot to tell u i have ADSL Not Cable Modem i don't know if that
makes a diff?
> KD
> > Internet Gateway
> > Internet Connection
> > Connecting
> > Internet Conection
> > 1394 Conection
> > 1394 Net Adapter
> > > KD
Reply to Roger
Hello , Also see the post in this catagory posted on 6/19/05 , topic :
'Wireless Security' posted by 'Clayton' .
KD
> makes a diff?
Reply to Installer
Hello , Correction .. the post date is 6/23/05 . Thank You .
KD
> KD
> > makes a diff?
Reply to Installer
There are 1210 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
