Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
I have a P4 3.0E Prescott running on an Intel 865PERLX motherboard, with
stock Intel cooling. Before I put in the 3.0GHz CPU my CPU fan would
increase speed as temperatures increased. Now it sits at around 2500RPM and
my temps are going through the roof (>60degrees C). I have tried plugging
the fan into the Vreg connection, the CPU fan connection and direct to the
PSU without any resolution. If I leave my case door off (Antec Sonata) it
decreases the CPU temperature. Is there a setting in the BIOS that I need
to turn on (I have speed settings enabled)? Is there something else that I
am missing? Any help would be greatly appreciated.
Thanks,
Lars
Thanks,
Lars
