G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
I have a PC with a combo drive and the audio cable is hooked up to the
only audio-input on my mobo. I'm installing a DVD-R drive. Do I need
to worry about the audio cable for that? And if so, what's the setup?
It's my understanding that those cables are only for sending audio
directly from the drive to the speakers, or something like that. I'm
not sure I ever needed the *first* cable.
Anyway, I have on-board 5.1 audio and plan on getting a 5.1 speaker set.
I'd like to be able to hear everything properly no matter what drive I
stick something into.
Thanks.
Thanks.
