Power Supply
Forum Homebuilt Systems : General Homebuilt - Power Supply
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Anyone know which pins to jump on a dell SG1 power supply to fire it. I
know it is green and black on a normal atx, but Dell is different. I am
trying to diagnose if the supply is bad or not. Pc will not start. thanks,
Ray
Sponsored Links
"Ray" <n8woz@excite.com> wrote in message news:<SYKdnVu27b7J037dRVn-jw@comcast.com>...
> fire it. I know it is green and black on a normal atx, but
> Dell is different. I am trying to diagnose if the supply is
Try grey to black, but if you want to play it safe, use a resistor
rated for approximately 300 ohms (even 1,000 ohms will almost always
work) instead of a jumper wire because then it'll be impossible to
damage the power supply, regardless of which lines are connected.
Reply to Anonymous
> Ray
Try connecting the grey and black wires together, but if you want to
play it safe, use a resistor of approximately 300 ohms (even 1,000
ohms will almost always work) instead of a jumper wire because then
it'll be impossible to cause any damage, regardless of which lines are
connected.
Reply to Anonymous
Thanks for the advice, will give it a try. There are numerous black wires,
I assume any will work?? The gray is in pin one position. thanks, Ray
"do_not_spam_me" <do_not_spam_me@my-deja.com> wrote in message
news:101710fa.0407011302.1be97fc4@posting.google.com...
thanks,
> > Ray
> connected.
Reply to ray
Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Power Supply
There are 998 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
