1979 Celica Choke (20R Engine)
G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
I'm checking the operation of the Choke on a 1979 Celica. The Factory
Service manual mentions the choke opener and choke breakers, which I found
and checked out OK.
Then they mention the Choke linkage diaphragm, which I can't find. Are they
referring to the other two? Choke breaker diaphragm is on driver's side,
choke opener on passenger side (same as AAP) but I can't find what Toyota
calls the "choke linkage diaphragm.". Where would this be in relation to the
other two? (This car has the "Federal" emmisions systems).
I'm troubleshooting a fast idle condition. The car has been idling at 1300
rpm or so. When I hit the accelerator quickly, the idle drops to 800 rpm.
When I suspected the choke, I observed the butterfly OPEN while the car was
racing at 1300 rpm's, however. Could this be a linkage problem? Throttle
return spring?
spencer
111
What is your FSB?
"tom418" <cscokid11768@yahoo.com> wrote in message
news:kuuIc.40734$oh.2046@lakeread05...
> and checked out OK.
they
the
was
> return spring?
G
Guest
Guest
Les than 800mhz, that's why Toyota's choke off the line without an updated
bios cow chip in their manifold.
"Spencer" <warthog@nospam.co.uk> wrote in message
news:ccu36c$m8r$1@hercules.btinternet.com...
> What is your FSB?
found
> > and checked out OK.
> they
side,
Toyota
> the
1300
rpm.
> was
Throttle
> > return spring?
G
Guest
Guest
Sounds to me like there's a nut loose in the operator's chair.
> found and checked out OK.
> Are they referring to the other two? Choke breaker diaphragm is on
> driver's side, choke opener on passenger side (same as AAP) but I
> can't find what Toyota calls the "choke linkage diaphragm.". Where
> would this be in relation to the other two? (This car has the
> 1300 rpm or so. When I hit the accelerator quickly, the idle drops to
> 800 rpm. When I suspected the choke, I observed the butterfly OPEN
> while the car was racing at 1300 rpm's, however. Could this be a
> linkage problem? Throttle return spring?
