Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
First I'm most grateful for all the advice submitted by you folks. Thank you
much......
Now for my bad news, my new hard drive is a Western Digital, 10,000 rpm
Raptor. I cannot seem to find a place to plug it in on my motherboard. The
hard drive is OEM and did not have any literature with it. It appears the
connection is a serial connection. Which I do not have a serial cable on the
motherboard to hook up to. In a nutshell I don't even know if my motherboard
supports this newest technology or if perhaps I just need a particular cable
or....... My motherboard is an Intel(R) Desktop Boards - D850EMV2
http://www.intel.com/design/motherbd/mv2/
I would certainly welcome any further advice or ideas. As before, thanks
again and take care....Rob
much......
