Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
I am having a lot of problems with my system. I have been having problems
with the system randomly rebooting on me. I thought that it might be a
heat issue at first cause it was running a bit hot. I got a new Volcano 12
heatsink and I'm running at about 47-48 degrees (CPU temp) now but I'm
still having the reboot problems. I recently got new RAM as well because I
thought that might be causing the problem but that didn't help either.
My system is an XP3200, MSI KT6V-LSR MB, Mushkin PC-3200 512mb RAM, Raidmax
case with 420W power supply, eVGA FX5700 video card, MSI CD burner, WD 80GB
HDD.
I have updated the BIOS to the newest version and I have the newest version
of all of the drivers. Currently I am running the FSB at 100mhz so that I
can at least use the stupid thing. The reboots occur at different times.
Sometimes it happens right after I boot the system other times it happens
after it has been running for a bit. Usually it won't last longer than
about 10 minutes before it reboots. Many times it won't even make it to
Windows before it reboots. I have installed fresh copies of both Windows
and Linux and neither seems to fix the problem. If anyone could give me
some recommendations I would really appreciate it, otherwise this thing is
going for a long ride tied to the back of my car.
HDD.
