Archived from groups: alt.comp.hardware.pc-homebuilt,alt.comp.hardware,uk.comp.homebuilt (
More info?)
Jeff Gaines wrote:
> On Wed, 11 Aug 2004 15:35:00 +0100, Michael Salem
> <a$-b$1@ms3.org.uk> wrote:
>>GwG wrote:
>>> Even if you
>>> switch off at the socket, most sockets only switch the live feed, and if
>>> the socket is incorrectly wired, (it does happen, it happened to me with
>>> a house that had been rewired by the Electric Board, they had crossed
>>> the feeds at the fuse box, reversing live and neutral throughout the
>>> whole house), you could get a shock whilst thinking you were safe. I
>>> grabbed hold of 240 volts, and was not too pleased with the person that
>>> did the rewire.
>>A possibly life-saving tip: if you touch something electrically live
>>with your fingers in the normal way, your muscles will contract, making
>>you press or grip the hazard.
>>If you stroke it gently with the backs of your fingers, you will feel if
>>it is live, but the muscular contraction will move your hand away from
>>the hazard.
>>Best wishes,
> Is that better than using a neon screwdriver
I've always wondered about the reliablity of those with regard to their
failure mode.
The advice is always to check them with a known live source, but how do
they fail? If they fail instantly, like light bulbs, they could work
when you tested them and then when you use them on the thing you want to
check it has failed but you think the circuit you're testing is dead.
Parish
If Bill Gates had a dime for every time a Windows box crashed...
... Oh, wait a minute, he already does."
This .sig was brought to you by Tagzilla <http://tagzilla.mozdev.org>
