G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
hi all
hope someone can help as I'm really tearing my hair out here with this... I
installed a second hard drive into my PC a month ago and it's been playing
up ever since...
When I first booted up the PC after the installation it was on for about a
nano-second then switched straight off again. I pressed the 'on' button and
again, it just died after a split-second. Pressed 'on' again and it finally
booted up fine. The new hard drive is working fine too.
However, I left the PC running overnight and found it dead the following
morning. Completely dead - even pressing the 'on' button did nothing... I
found that unplugging the power cable from the back of the PC and leaving it
for a few seconds then plugging back in and hitting the 'on' button brings
it back to life - for a split-second. Then, once again I have to keep
pressing 'on' repeatedly until it finally stays on and boots up!!
Windows is a bit corrupted and needs a reload at some point so I find myself
having to regularly restart the PC due to it freezing up. This also results
in the same thing as above happening. The PC switches off as normal then
starts to reboot until a split-second later when, boom, it's dead again.
Press 'on' about 10 times and it finally properly comes to life..
So... it's a flippin nightmare. I'm terrified that one day it's gonna die
for good and there will no turning it back on at all.
Any ideas as to what could be causing it or has anyone ever encountered
anything similar?
Thanks in advance.
Daz
hi all
up ever since...
anything similar?
Thanks in advance.
Daz
