New system Build
Building new system, does all this sound compatible? Still need to run some 32 bit XP programs (don't laugh), will probably stick with onboard video (VGA for a while)
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor HDZ965FBGMBOX
ASUS M4A89GTD PRO/USB3 AM3 AMD 890GX HDMI SATA 6Gb/s USB 3.0 ATX AMD Motherboard
CORSAIR XMS3 8GB (4 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMX8GX3M4A1600C9
Seasonic X650 Gold 650W ATX12V V2.3/EPS 12V V2.91 SLI Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
Seagate SV35 Series ST31000526SV 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive - Model #:ST31000526SV
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
Model #RW-24B1ST/BLK/B/AS
Microsoft Windows 7 Professional 64-bit 1-Pack for System Builders - OEM
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel ...
Model #:RR-B10-212P-G1
2 answers Last reply
More about system build
  1. Everything is compatible here. Though you say you need to still run XP 32-bit programs, but you are installing Win 7 Pro 64-bit? It may not be compatible, but you can run a dual boot system where you can boot into both XP 32-bit and Win 7 64-bit.
    If you wanted, post here in detail what you want to use the computer for, and I can give you my recommendations of what would be best for your system (and your wallet!)
    Thanks, ocassional video editing, encoding music collection, word perfect x3 (for wife, I use open office), old games (none to require heavy graphics engine). I want it FAST though, was hoping to run old software in xp compatible mode or virtual box, so I don't have to buy all new software at once.
    Thanks in advance
Configuration Windows 7
