G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Using ghost from system works 2003, I save a partition to an image on a new
drive. Old drive removed, new drive installed. Do a restart and system wont
boot ie no boot device.
Ok set partition to active using xp diskmanager in another box (I think I
also used a dos boot floppy to set active partition once). new system now
boots but wont go past the welcome screen in xp, ie just before the login
screen showing users appears. I've managed to repeat the problem a few
times.I have tried the repair option and safe boots but still no luck.
any help much appreciated.
