old mobo battery question
G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Howdy.
Still trying to get this old Asus PCI/I-P54TP4 rev 1.32 motherboard up
and running. Actually it is up and running, just not tweaked yet.
Where's the darn battery? I am having troubles with email and firewall
because of the time. It keeps saying it is 2094 and I keep changing it
back to 2004 in the BIOS and on the sys tray. I figure it's the
battery, but can't seem to locate the mangey thing.
All I could find was something that looked like a chip (but isn't),
rectangle in shape that has an alarm type clock on it with this:
Dallas
DS12887
RealTime
9508A2 057158
Can't tell if it can be romoved or not. Am I on a snipe hunt here??
Could it posible be a year 2000 thing? I'm running Win98 on the box.
Am I grasping at straws here? :)
The Seabat
G
Guest
Guest
seabat wrote:
> Howdy.
> Dallas
> DS12887
> RealTime
> 9508A2 057158
I'm impressed you deduced it. Yep, that's it. Dallas (now Maxim) made/makes
a number of 'battery inside' devices. Here's the data for yours...
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/2681/ln/en
App note on replacing it
http://www.maxim-ic.com/appnotes.cfm/appnote_number/769
Not a windows problem.
