Archived from groups: alt.comp.hardware.pc-homebuilt (
More info?)
Craig wrote:
> Yeah that's what it is. So far ECS hasn't been able to help. Not quite sure
> what to do. I was checking around in the win.ini file and the sounds
> systemdefault is set to ",". Not sure if that's the problem.
[Sounds]
SystemDefault=,
is not a problem. I don't know what the heck it means either but the exact
same thing is in one of my machines (not K7S5A) that's working perfectly fine.
Off hand I'd say you got the wrong driver but I can't give you the exact
'file name' because mine is a refurb and didn't come with the CD (for me to
look at). And since I'm running XP that's only one I downloaded.
The other thing I can pass on is don't use PCI slot 1, the one next to AGP.
It don't work worth spit.
Also, on-board devices are 'PCI cards', without the 'card', meaning they
'use' a PCI slot, like a card. If you have any PCI cards plugged then try
moving it to a different slot because if it's in the same slot the sound
chip is using then it could be interfering.
> "David Maynard" <dNOTmayn@ev1.net> wrote in message
> news:10m3uju5v2lmo64@corp.supernews.com...
> Craig wrote:
>>"Shep©" <nospam@nospam.net> wrote in message
>>news:0ml3m09l86fh6q6f55nr1imomtcle6iudm@4ax.com...
>>>On Sun, 03 Oct 2004 21:43:33 GMT There I was minding my own business
>>>Check that,"All" the on-board BIOS sound settings are correct.
>>>You don't mention what O/S or what sound chip
>>I'm running win98se. The sound chip is the c-media 9738 (?) or it's a sis
>>7012. The motherboard is an ECS K7S5A PRO.
> Ah HAH!. Information.
> Audio on the K7S5A Pro is C-Media AC97.
> The controller is SiS 7012. The CODEC is CMI9738
