250W (max) power supply
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
I want to upgrade my old PIII 450 with Asus P3B-F. I want to do it as
cheap as possible, such as grabbing a CPU/mobo combo from some Fry's
deals.
One concern for me is that the old power supply is 250W max in the ATX
case. Will this be enough to drive modern CPU systems like AthlonXP
(Barton) or Sempron? Currently I'm only considering to replace the CPU,
motherboard and some new format DDR memory under $150. So if I have to
upgrade the power supply as well, it would be a different story.
And ideas? Thanks.
6 answers Last reply
More about 250w power supply
  1. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    "egf_repeats" <egf_repeats@hotmail.com> wrote in message
    news:1096915860.924727.244590@k17g2000odb.googlegroups.com...
    > deals.
    > And ideas? Thanks.
    It'll be enough for the Sempron, assuming your video card doesn't have a
    power connector. But that also assumes your 250W is really 250W. Try the
    following. -Dave
    http://www.mwave.com/mwave/viewspec.hmx?scriteria=BA19274
  2. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    > deals.
    Depending on what you want to accomplish from the 'upgrade' you might want
    to look into putting a 1.1 to 1.4 gig Celeron Tualatin on it. Upgradeware
    makes the "Slot-T" slotket for doing just that. You'd want to check your
    board rev level and their compatibility list.
    In theory 250W would be enough, if the PSU really did it and you weren't
    going to use some super duper high powered video card, but probably not the
    one you have because more modern systems moved much of their power
    consumption from the 3.3 and 5 volt rails to the 12 volt rail, which means
    that the '250w' in your power supply is, most likely, 'in the wrong place'.
    However, it's possible you could sneak in a low end XP minimal system (no
    fancy video, single hard drive, one CD) if you checked the 12 volt power
    carefully. But it's a gamble, especially with the PSU being old.
    > And ideas? Thanks.
  3. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    250 watts is not enough power.
    DaveW
    > deals.
    > And ideas? Thanks.
  4. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    > deals.
    > And ideas? Thanks.
    Some 250 W power supplies are better than others. In my previous
    computer, a Dell P2 400 MHz, I was running three hard drives, a CD
    ROM, a DVD -RW/+RW burner, sound card, video card, floppy drive,
    ATA 100 Promise BIOS card, parallel port card, modem, and powering
    two USB ports, all on a 250 Watt PSU. Ran this way for years,
    never had a single problem. Still running, in fact.
    For modern chips and motherboards, personally I wouldn't go below
    a 300 W power supply. I don't think 250 W cuts it anymore. With
    350 W you will feel comfortable upgrading. With 400 W, you're
    laughing. Anything more than 400 Watts is unnecessary, no matter
    what you're going to put into the case. That's my own rule of
    thumb, anyway.
  5. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    On Mon, 4 Oct 2004 15:27:55 -0400 There I was minding my own business
    >> deals.
    >> And ideas? Thanks.
    >following. -Dave
    As you say but for a few pounds/dollars and if there are problems the
    O/P knows where they will come from.Age of his supply is against it as
    well :/
    Free Windows/PC help,
    http://www.geocities.com/sheppola/trouble.html
    remove obvious to reply
    email shep@obviouspartyheld.de
    Free songs to download and,"BURN" :O)
    http://www.soundclick.com/bands/8/nomessiahsmusic.htm
  6. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    "egf_repeats" <egf_repeats@hotmail.com> wrote in message news:<1096915860.924727.244590@k17g2000odb.googlegroups.com>...
    > deals.
    I had a really bad 250W PSU (PC Power & Cooling used the 300W version
    as an example of how bad one could be) that couldn't reliably power
    just a mobo, slow graphics card, and 1.3 GHz Duron. OTOH one person
    recently said that his 250W Fortron/Sparkle had no problems running a
    much faster CPU & graphics card and a pair of 7200 RPM HDs and at
    least one optical drive.
    http://takaman.jp has a power estimation program that doesn't
    exaggerate the power as much as others do, and it gives estimates for
    the amps from each
    voltage rail as well (but you may have to triple the +3.3V amp
    figure).
    I'm using a Celeron at 450 MHz (slow graphics card, 1 CD-RW, 1 5400
    RPM HD), and I think that the power consumption was only about 60W.
    Did you miss the Fry's $15-after-rebate Antec 350W SmartPower PSU deal
    last week? They also had an Antec case w/ 300W SmartPower for $25
    after rebate, and the box for the case said that it was OK for 3 GHz.
    The 300W SmartPower has been changed and is now rated for 19A @ +12V,
    compared to 15-16A for older models, and the 350W model is now rated
    for 21A @ +12V.
Homebuilt Power Supplies CPUs Systems
