G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
I bought the OCZ ultra high performance Dual channel kit (2x512MB)
PC3200 item number: OCZ4001024V3DC-K
(http://www.ocztechnology.com/products/memory/ocz_ddr_pc_3200_value_series_dual_channel)for
my Dell dimension 4600.
When I installed the memory, the computer is beeping and nothing shows
up.
The memory supported by my dell 4600 can be found here:
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/specs.htm#1105699
I'd like to know if the OCZ memory I bought is compatible with my
system or I should return it. If it's compatible I'd like to know what
I should do to make it work.
Does anyone have tried to install such a module for a dell 4600?
Thanks,
-Stephane
up.
Thanks,
-Stephane
