Move hard drive to new motherboard/cpu/RAM/Operating system
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
I want to upgrade my grandson's PC, currently WinME on ASUS P2B, Intel
PII 800mhz,768MB PC100, to WinXP Pro on ASUS P4R800-VM, Intel P4
2.8ghz, 1024MB PC3200, retaining the existing hard drive with all his
applications and data.
Clearly the hardware changes, especially the move to a hyperthreading
processor will give Windows indigestion.
Is it better to upgrade the Op System to WinXP Pro,then make the
hardware change or do the hardware first?
I'd prefer to leave the Windows upgrade to last so that all the
hardware is compatible with WinXP but is that the best route to go?
Whichever route is best, how do I ensure that the Windows on the hard
drive recognises the new hardware ??
Thanks for all guidance....step by step description would be much
appreciated by grandpa!
9 answers Last reply
More about move hard drive motherboard operating system
  1. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    You'd be better off with a clean install of xp. You can do this without
    installing Me first. Just boot to the xp disc, and at some point in the
    install, it'll ask for the Me disc to make sure you have a previous OS
    you're upgrading from. A clean install is always preferred when changing
    hardware, especially to that extreme. You don't want to leave
    everything as is and just upgrade. First off, the drivers from the
    previous hardware will still be in windows, and may conflict with the
    new drivers for the new hardware. Save yourself several headaches and
    just clean install.
  2. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    WinME to XP 'upgrade' install? You'll regret it...
    Perhaps not, if you don't boot to windows after setting the hardware up:
    go straight to the XP install. But like I hinted at above, you'd be
    better off doing a clean install and restoring the data from
    backups/resintalling software. A lot of software on WinMe/9x machines is
    not XP compatible and will bugger up XP after an upgrade install.
    spammage trappage: replace fishies_ with yahoo
    I'm going to die rather sooner than I'd like. I tried to protect my
    neighbours from crime, and became the victim of it. To jump to the end
    of the story, as a result of this I need a bone marrow transplant. Many
    people around the world are waiting for a marrow transplant, too. Please
    volunteer to be a marrow donor:
    http://www.abmdr.org.au/
    http://www.marrow.org/
  3. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    On 18 Oct 2004 02:26:25 -0700 There I was minding my own business and
    I'd upgrade to WinXP pro now.Then move the drive over,then do a repair
    install of XP on the new system as per,
    http://www.webtree.ca/windowsxp/repair_xp.htm
    You will most likely have to install some newer mother board drivers
    for the new system but you would most likely have to do this even if
    you did a clean re-install.
    Useful bookmarks,
    http://www.tipsdr.com/
    http://www.winxpfix.com/
    I've upgraded many systems this way with no problems as I don't always
    have the luxury of being able to clean re-install.Also,
    Regscrub XP,
    http://www.freedownloadscenter.com/Reviews/r882.html
    Is an excellent registry cleaner to use on a regular basis with XP.
    You may also have to visit the video card and sound card makers etc to
    look for XP drivers if required.If you need more info on the system
    hardware then download,"Everest Home Edition" a very useful free
    program that will tell you all about nay system's hardware etc,
    http://www.geocities.com/sheppola/diag.html
    HTH :)
    Free Windows/PC help,
    http://www.geocities.com/sheppola/trouble.html
    remove obvious to reply
    email shep@obviouspartyheld.de
    Free songs to download and,"BURN" :O)
    http://www.soundclick.com/bands/8/nomessiahsmusic.htm
  4. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    Cannot really be done the way you want to safely. If you change the
    motherboard that a given harddrive's OS setup has been used with then you
    MUST do a clean install of the OS on the new computer, and let the hardware
    of the new system be detected during the new OS installation. Otherwise you
    risk nasty ongoing Registry errors.
    DaveW
    "driver" <strokedriver@btopenworld.com> wrote in message
    news:382bff29.0410180126.3fb5a80f@posting.google.com...
  5. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    You may safely ignore the paranoid babblings of DaveW on this matter.
  6. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    "DaveW" <none@zero.org> wrote in message
    news:MfYcd.493498$8_6.287708@attbi_s04...
    > hardware of the new system be detected during the new OS installation.
    > Otherwise you risk nasty ongoing Registry errors.
    > DaveW
    Driver:
    If I understand you correctly, you plan to change the
    motherboard/processor/RAM and then install XP as an upgrade to the present
    Me OS.
    I'm not sure I understand your comment that "the move to a hyperthreading
    processor will give Windows indigestion." There should be no problem with
    this change that would cause any difficulty with the new Windows OS.
    After you've installed the new motherboard/processor/RAM, simply install the
    Windows XP OS (using XP's bootable installation CD) as an upgrade to the
    current Me OS. There's a strong likelihood that XP will furnish the
    necessary drivers for your existing hardware, however, you will most likely
    also install the drivers provided on the ASUS installation CD that
    accompanied the motherboard. Obviously, should any other drivers are needed,
    e.g. the video card, not provided by XP or ASUS, they will have to be
    provided by you.
    In virtually every case of installing XP over Me, the upgrade goes smoothly
    and without incident. In virtually every case, there is no need to perform a
    "clean install" in order to avoid "nasty ongoing Registry errors". I've
    performed dozens of similar upgrades and have never run into a single
    problem along these lines. I've found XP to be a very well-behaved OS when
    it comes to upgrading a Win98/Me OS.
    Art
  7. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    On Mon, 18 Oct 2004 23:23:24 GMT There I was minding my own business
    Same old shite.
  8. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    Thanks for all the comments and suggestions.
    Shep, I am grateful for the links, especially Everest Home Edition, a
    very neat little utility.
    We will take the plunge this weekend..I will report back how we do.
    Thanks again
  9. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    On 19 Oct 2004 13:30:43 -0700 There I was minding my own business and
    >Thanks again
    There's plenty of good folk out here who will help :P
Homebuilt Hardware Hard Drives Motherboards Systems
