Legacy Scanner Problem
Forum Windows 95/98/ME : Windows 95/98/Me General Discussion - Legacy Scanner Problem
Archived from groups: microsoft.public.windowsme.general (More info?)
I have a system (200MHZ, 4GB HDD, 128MB RAM) that I have upgraded to WIN ME;
previous OS was WIN95. On the previous install with '95 everything worked
correctly; I have a sheetfed scanner (ISA board, Info ImageReader SE6C).
The scanner worked fine with 95, but cannot be used with WIN ME. Any
suggestions, the error is always from the scanner software: scandevc.sys not
installed. Any suggestions...I've tried 6 or 7 drivers and rebuilt 2x.
Kurt
Sponsored Links
If the scanner requires real mode drivers loaded via config.sys (such as
perhaps scandevc.sys) then it is incompatible with, and cannot be used
with Win Me since Win Me does not support real mode.
Mike Maltby MS-MVP
mike.maltby@gmail.com
> WIN ME; previous OS was WIN95. On the previous install with '95
> everything worked correctly; I have a sheetfed scanner (ISA board,
> Info ImageReader SE6C). The scanner worked fine with 95, but cannot
> be used with WIN ME. Any suggestions, the error is always from the
> scanner software: scandevc.sys not installed. Any suggestions...I've
> tried 6 or 7 drivers and rebuilt 2x. Kurt
Reply to Anonymous
>Kurt
You could try using a utility named CTLOAD.EXE to install the drivers
that would normally be in the config.sys file. No guarantee but it
is worth trying.
I found a download site for it at
http://www.liaokai.com/softw_en/dos.htm
Good luck
Ron Martell Duncan B.C. Canada
Microsoft MVP
On-Line Help Computer Service
http://onlinehelp.bc.ca
"The reason computer chips are so small is computers don't eat much."
Reply to Anonymous
Thank you Ron for the recommendation; I considered CTLoad, but noticed it
was not the exact fix I needed. I found a work around by using a "Real
DOS_Mode Patch for Windows Millennium by Reines (MFD)". I did the trick and
was very easy to apply.
"Kurtis Myers" <myers6516@hotmail.com> wrote in message
news:uMu4ajWBFHA.3588@TK2MSFTNGP11.phx.gbl...
>ME; previous OS was WIN95. On the previous install with '95 everything
>worked correctly; I have a sheetfed scanner (ISA board, Info ImageReader
>SE6C). The scanner worked fine with 95, but cannot be used with WIN ME.
>Any suggestions, the error is always from the scanner software:
>scandevc.sys not installed. Any suggestions...I've tried 6 or 7 drivers
>and rebuilt 2x.
> Kurt
Reply to Anonymous
OH DEAR!!!
I do hope you don't ever need to use Safe Mode!
Noel Paton (MS-MVP 2002-2005, Windows)
Nil Carborundum Illegitemi
http://www.btinternet.com/~winnoel/millsrpch.htm
http://tinyurl.com/6oztj
Please read http://dts-l.org/goodpost.htm on how to post messages to NG's
news:%23dpBBqtBFHA.1404@TK2MSFTNGP11.phx.gbl...
> and was very easy to apply.
>>and rebuilt 2x.
>> Kurt
Reply to Anonymous
My thoughts as well Noel which is why I chose not to refer to this
so-called solution in my original post to this thread.
Mike Maltby MS-MVP
Noel Paton <NoelDPspamless@btopenworld.com> wrote:
> OH DEAR!!!
Reply to Anonymous
Tom's Hardware > Forum > Windows 95/98/ME > Windows 95/98/Me General Discussion > Legacy Scanner Problem
There are 990 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
