Need input/opinions on a new build Shuttle please
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Hi all,
I am planning to build a Shuttle rig for myself. I am a first
time PC builder and would like some input on the parts I am choosing.
Thanks for your help.
1) ATI RADEON 9800 PRO Video Card, 256MB DDR, 256-bit, DVI/TV-Out,
8X AGP
http://www.newegg.com/app/viewProductDesc.asp?description=14-102-361&depa=0
2) Intel Pentium 4/ 3.0C GHz 800MHz FSB, 512KB L2 Cache, Hyper
Threading Technology
http://www.newegg.com/app/viewProductDesc.asp?description=19-116-156&depa=0
3) Corsair XMS Extreme Memory Speed Series, (Twin Pack) 184 Pin
1GB(512MBx2) DDR PC-4000 with Platinum-Silver Heat Spreader Model#
TWINX1024-4000PT
http://www.newegg.com/app/viewProductDesc.asp?description=20-145-454&depa=0
4) Western Digital 200GB 7200RPM SATA Hard Drive, Model WD2000JD
http://www.newegg.com/app/viewProductDesc.asp?description=22-144-153&depa=0
5) Plextor 12X DVD+/-RW Drive, Model PX-712A Black
http://www.newegg.com/app/SearchProductResult.asp?Description=27-131-327&DEPA=
6) Shuttle XPC Black Barebone System for Socket 478 at
533/800MHz FSB Intel CPU, Model SB75G2 V2
http://www.newegg.com/app/viewproduct.asp?description=56-101-431
On a side note, should i use thermal pad that is included or Artic
Silver paste? heat pipe
or fan/heat sink combo? Will I have any BIOS issues with the SATA HD?
Thanks again..
6 answers Last reply
More about need input opinions build shuttle please
  1. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    <MrBacala@hotmail.com> wrote in message
    news:5128p0peks731t6edship3i60btjkmoc79@4ax.com...
    > Hi all,
    > 8X AGP
    > TWINX1024-4000PT
    > Thanks again..
    Looks good. I built mine last December using the SB65G2 bare bones, 3gHz P4,
    ASUS 9600 video, 512mB of Corsair 3200 memory, 160gB SATA, and Plextor 708A
    (current at the time), and a Mitsumi combo floppy/flash drive. A very easy
    build. No issues with the SATA. You will almost certainly need to use the
    Shuttle heatpipe which works quite effectively keeping my CPU at ~50C when
    the system is running at 100% load (and have you seen how tight these
    computers are inside? probably no room for any other sort of heatsink). One
    slight change I made was to add a tiny (40mm?) fan to cool the PWM area on
    the right side of the MB which appears to be in an area of stagnant air
    flow -- I literally stuck the fan to the tops of the filter caps using
    hot-melt glue so it blows a bit of extra air down across the switching
    components. No extra noise that I can detect.
    The space available for the video card is a bit limited so if your intended
    one takes any more than 1 slot worth of space it probably won't work. I
    chose the ASUS version of the 9600 as being "fast enough" for my purposes
    and because it includes video input which many don't. Since you are a first
    time builder I'd advise a lot of care with the assembly of the Shuttle -- it
    isn't nearly as easy as one of the "big box" systems to put together but it
    can be done very neatly if you take your time. You'll need to be especially
    careful about lead dress in a system like this since airflow can easily be
    blocked by a badly placed ribbon cable and there are no extra fans to make
    up the defecit. http://johnmcgaw.com/furn28.html
    John McGaw
    [Knoxville, TN, USA]
  2. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    Why a Pentium 4? Why not an Athlon 64?
    The Athlon 64 is a great performer running 32 bit software using a
    32 bit operating system. If you use a 64 bit operating system, you
    can run 32 bit software side by side with 64 bit software. Many
    people who buy a 32 bit processor in '04 or ealy '05, will probably
    regret not buying a 64 bit processor instead, as plenty of great 64 bit
    software is released in the second half of '05.
    http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=2065&p=6
    http://www.short-media.com/review.php?r=257&p=1
    > > Hi all,
    > > 8X AGP
    > > TWINX1024-4000PT
    > > Thanks again..
    > John McGaw
  3. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    "JK" <JK9821@netscape.net> wrote in message
    news:41943476.5ECF3B10@netscape.net...
    According to www.pricewatch.com, same price range at the moment would be:
    P4 3.2 Prescott vs. Athlon64 3200+ or
    P4 3.4 Prescott vs. Athlon64 3400+
    Beyond that range, you can pay up to several hundred dollars for either an
    Intel or AMD chip, but hardly anybody gives a damn about those chips, as
    hardly anybody spends as much on a processor as they do on the entire rest
    of their system combined.
    So the P4 3.2/3.4 and Athlon64 3200/3400 would be the best indicators of who
    has the best bang for buck, at the moment.
    Gaming: OpenGL: The Intel chips are much faster
    Gaming: DX8: The AMD chips are faster, no doubt about it
    Gaming: DX9: It's virtually a tie, as the AMD chips are two to three
    TENTHS of a percentage point faster than Intel.
    So on the gaming benchmarks, that's one win for Intel, one win for AMD and
    one tie.
    GAMING OVERALL: TIED
    Business Applications: Office Applications: Intel blows AMD away
    Business Applications: Internet Content Creation: Intel blows AMD away
    Business Applications: Overall: Intel blows AMD away
    Video Encoding: This one is so lopsided, AMD should have thrown in the
    towel before entering the ring. Intel wins by a landslide.
    Audio Encoding: Again, Intel wins by a landslide
    Synthetic Benchmarks: (PC Mark 2004): Here, Intel blows AMD away on both
    *CPU* and memory benchmarks
    http://www.tomshardware.com/cpu/20040322/index.html
    Even at the same price for CPU, an Intel system can be cheaper to
    build, as the P4 boards are more mature at this point, and thus there are
    better bargains to be found. Considering that an Intel system will likely
    be cheaper to build and WILL perform better on all benchmarks except DX8,
    it's kind of a no-brainer as to which chip to build with, at the moment.
    The following is an article on the Athlon 64 2800+. But more interesting
    is,
    the benchmarks included in the article are a GREAT comparison of the 3.2GHz
    P4
    processors with the Athlon64 3200+. In this article, these two processors
    are
    pretty evenly matched, with Intel being faster on some benchmarks, and AMD
    being faster on others.
    http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=2038&p=1
    Now lets look at what Sharky Extreme has to report in their article about
    the
    3.4GHz Prescott processor. This one has benchmarks that are a great
    comparison
    of the 3.4GHz Intel chips with the Athlon64 3400+. Here, you have to be
    careful,
    as Sharky doesn't organize their charts in order of fastest to slowest. And
    on
    some charts, LOWER scores are better. But if you read all the benchmarks,
    you
    will again notice that the two chips are pretty evenly matched, with AMD
    faster
    on some and Intel faster on others.
    http://www.sharkyextreme.com/hardware/cpu/article.php/3261_3329681__1
    Intel is better than AMD, at the moment. The only way AMD could change that
    would be to drop their prices by 30% or better. -Dave, updated 10/19/04
  4. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    > Hi all,
    > 8X AGP
    > TWINX1024-4000PT
    > Thanks again..
    Everybody seems to be choosing Plextor, probably cause it's Plextor. But
    dual layer burners have been out for quite a while now. Shame on Plextor
    for being so slow to get their dual layer burner on the market. Plextor is
    great, but any single layer burner is obsolete already, even if it's the
    fastest burner on the market. Try the following instead . . .
    http://www.newegg.com/app/ViewProductDesc.asp?description=27-152-029&depa=0
    I believe that comes with Roxio software, which is OK. If it does come with
    Roxio, and you prefer Nero (I've used recent versions of both, and they are
    both great), you can get Nero for about 20 bucks here:
    http://www.isellsurplus.com/product.asp?id=6362&c=30&s=161
    Everything else looks OK. Shuttle is a great brand, if you are building
    SFF. I'm going to suggest an alternative that you might not have
    considered, though. The following is great quality, almost as small, and
    much more flexible, as far as upgrading goes.
    http://www.newegg.com/app/viewProductDesc.asp?description=11-129-146&depa=0
    Note that it's also $200 less than the shuttle box you chose, which leaves
    plenty of money in your budget to find any micro-ATX format mainboard for
    it. The following doesn't look too bad:
    http://www.newegg.com/app/ViewProductDesc.asp?description=13-127-160&depa=0
    On a side note, I've also built a similar system with the following board
    and a Prescott processor. Although it's a VIA chipset, it turned out to be
    a very stable and EXTREMELY fast system, according to several benchmarks we
    ran on it. We paired it up with a Chaintech brand FX5900XT video card, but
    your Radeon 9800 Pro would be even faster.
    http://www.newegg.com/app/ViewProductDesc.asp?description=13-138-020&depa=0
    NOTE: The shuttle box you chose has a 250W power supply, which is not
    adequate for a FX5900XT video card (300W minimum). While I don't anticipate
    you'll have any problems building the Shuttle box, you might want to check
    the system requirements for your Radeon 9800 Pro before you build anything.
    That card might be too much for the Antec Aria also, as the Aria has a 300W
    power supply. (just adequate for the FX5900XT) -Dave
  5. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    Not quite. The Athlon 64 3500+ is virtually the same price as the Prescott 3.4 ghz.
    Not quite.
    http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=2065&p=10
    > one tie.
    Not quite. Even an Athlon XP3000+($95) beats a Pentium 4 3.2 ghz in Business Winstone
    2004.
    Not quite. See the Content Creation Winstone 2004 results.
    Even an Athlon XP3000+($95) beats a Pentium 4 3.2 ghz in Business Winstone 2004.
    > is,
    > P4
    > are
    > the
    > comparison
    > careful,
    > on
    > you
    > faster
    Very funny. A $150 Athlon 64 3000+ (socket 754 )beats an $780 Pentium 4 3.2 ghz in Doom 3.
    http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=2149&p=7
    A $95 Athlon XP3000+ beats a $210 Pentium 4 3.2 ghz in Business Winstone 2004.
    http://techny.com/articles.cfm?getarticle=606&go=0.53769656
  6. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    MrBacala@hotmail.com wrote:
    >Hi all,
    Hi one
    Here is some guessing.
    The one you're choosing might not be very upgradable. I guess there are
    other reasons to build a PC, but the ability to upgrade as I go is most
    important to me. I also realize that a bare-bones system plus peripherals
    might be good for your first time. However, if you want an easy
    introduction, why not buy a preassembled but upgradable PC? I'm no expert
    on the choices there, many new systems I have noticed are not very
    upgradable. You would need advice about that. If you were to do so, maybe
    after upgrading a few components, sooner or later you would buy a new
    mainboard, or case and power supply. At that point, you would be
    completely into building a PC. Since you want to build it, you're only
    interest isn't just the fastest or the best.
    Providing more information about what you want might help.
    Why do you want to build your own? What do you want out of it? What
    applications/games do you want to run?
    Good luck.
    >8X AGP
    &depa=0
    &depa=0
    >TWINX1024-4000PT
    &depa=0
    &depa=0
    &DEPA=
    >Thanks again..
Homebuilt Shuttle Systems
