Tom's Hardware > Forum > Windows 95/98/ME > Windows 95/98/Me General Discussion > Spyware problem with "...command=regedit.exe "%1"
Forum Windows 95/98/ME : Windows 95/98/Me General Discussion - Spyware problem with "...command=regedit.exe "%1"
Archived from groups: microsoft.public.windowsme.general (More info?)
Each day I run the spyware programs and virus program.
Lately Spy-bot and Ad-Aware have been detecting the
following entry into the WinME CLASSES registry
HKEY_CLASSES_ROOT\regfile\shell\open\command\=regedit.exe "%1"
My first question is what is it, and where is it coming
from? Seems that Windows loads it. I say that because I've
been trying to determine the culprit by not automatically
starting programs.
The next question is how dangerous is it?
Finally, how do I get rid of it (if it really is dangerous)
once and for all?
Thanks,
Dave
Sponsored Links
Those software are flagging that ?
Looks pretty normal to me.
Basically it is saying the class of files known as "regfile" are to be opened by REGEDIT.EXE
with the name of the file being the first switch parameter.
The only question I have is that the exact syntax ?
I ask this because of the equal sign (=) before REGEDIT.EXE.
Dave
"Dave Boland" <NOSPAMdboland9@stny.rr.com> wrote in message
news:UYtOd.29241$8H2.26939@twister.nyroc.rr.com...
| starting programs.
| once and for all?
| Thanks,
| Dave
Reply to Anonymous
Dave,
I'm unclear as to why SpyBot or AdAware should be flagging this entry as
it is quite normal although I'm a bit uncertain about the nomenclature
used. Basically I would expect to see at the key:
the Default string value: regedit.exe "%1"
What this means is that in association with the key:
HKEY_CLASSES_ROOT\.reg
the default action when attempting to open a file with a REG extension is
to use Regedit.exe.
Mike Maltby MS-MVP
mike.maltby@gmail.com
> starting programs.
> once and for all?
Reply to Anonymous
> Each day I run the spyware programs and virus program. Lately Spy-bot and
> Ad-Aware have been detecting the following entry into the WinME CLASSES
> registry
Strange. That is the registry key that sets Regedit as the default
application for opening *.reg files (Registration Entries) and is perfectly
legit. So when you double-click a (valid) file with a .reg extension,
Regedit.exe opens it - and you're asked if you want to add the information
in whatever.reg into the registry. Click Yes, and it goes in.
The default action for d-clicking a reg file can be changed to Edit, thus to
open in a text editor instead, which is much safer. Then if you know you
want to add the information within it to the registry, you r-click and
select Merge.
However, I fail to see why Spybot and Ad-aware are alerting on this entry,
or if they're set to alert on changes, why that one has been changed (to
what it should be anyway!). What else do they say, what are the details?
Shane
Reply to Shane
> to open in a text editor instead, which is much safer. Then if you know
> you want to add the information within it to the registry, you r-click and
> select Merge.
Unless it was previously set to open regfiles in Notepad and has now been
reverted?
Shane
Reply to Shane
David and others,
After doing some more homework, here is what I'm finding.
1. As soon as WindowsME is up, I run regedit to look at
HKEY_CLASSES_ROOT\regfile\open\command The contents are
actually Name = [Default], and Data = "D:\SCRIPT
SENTRY\SCRIPTSENTRY.exe "%1"%"
Script Sentry is a program to protect my system from scripts
that are used in Microsoft products. This is a program that
I installed.
2. I run Spybot and it says:
Common Extension hijack: Default registry file handler
(Registry change, nothing done)
"%1"
This is what will be in the entry if I except it. I'm not
going to accept it because I want Script Sentry to process
it first.
So, I guess I have a false alarm?
Dave,
Reply to Anonymous
> and Ad-Aware have been detecting the following entry into the WinME
> CLASSES registry
> My first question is what is it, and where is it coming from? Seems
> that Windows loads it. I say that because I've been trying to determine
> the culprit by not automatically starting programs.
> Finally, how do I get rid of it (if it really is dangerous) once and for
> all?
> Thanks,
> Dave
Mine commonly flag Regedit as an MRU item if that helps... perhaps it
thinks you should rename regedit to something else for security's sake
or at least disable the .reg association.
Rick
Reply to Anonymous
Yes. It looked at SCRIPT SENTRY as malware.
Dave L.
news:NNuOd.29248$8H2.19105@twister.nyroc.rr.com...
REGEDIT.EXE
| David and others,
| I installed.
| "%1"
| it first.
| Dave,
Reply to Anonymous
> David and others,
> HKEY_CLASSES_ROOT\regfile\open\command The contents are actually Name =
> [Default], and Data = "D:\SCRIPT SENTRY\SCRIPTSENTRY.exe "%1"%"
> Script Sentry is a program to protect my system from scripts that are used
> in Microsoft products. This is a program that I installed.
> Common Extension hijack: Default registry file handler (Registry change,
> nothing done)
> This is what will be in the entry if I except it. I'm not going to accept
> it because I want Script Sentry to process it first.
Yes. You should set SB and AAW to ignore that particular on.
Shane
Reply to Shane
>> thus to open in a text editor instead, which is much safer. Then if
>> you know you want to add the information within it to the registry,
>> you r-click and select Merge.
>> entry, or if they're set to alert on changes, why that one has been
>> changed (to what it should be anyway!).
> been reverted?
You can change this entry back and forth with these Registry patches from
http://aumha.org/regfiles.htm -
To set .REG files to open in Notepad by default:
http://aumha.org/downloads/editreg.zip
To set .REG files back to open with RegEdit by default:
http://aumha.org/downloads/uneditreg.zip
Jim Eshelman, MS-MVP Windows/Security
Windows Support Center: http://aumha.org/
AumHa Forums: http://aumha.net/
Reply to Anonymous
> starting programs.
> once and for all?
You've had a lot of helpful responses. I doubt it's a problem, but that
isn't completely clear yet.
What I haven't seen is anyone give you a recommendation for how to identify
whether or not there really is a problem, and what to do about it if there
is. Here are the steps I recommend:
http://aumha.org/a/quickfix.htm
Reply to Anonymous
"Jim Eshelman" <newsgroups@NSaumha.org> wrote in message
news:Os3V79vDFHA.2632@TK2MSFTNGP12.phx.gbl...
>> been reverted?
I did look for those, Jim (hence why my post was later than Dave and
Mike's). Didn't see them in the Registry section and thought better of
elaborating further.
Shane
Reply to Shane
Rather than using a registry patch to open REG files in notepad or regedit
all that is necessary is to use Control Panel | Folder Options | File
Types, select the REG extension, click Advanced and set the default action
to Edit (to open in Notepad) or Merge (to run using Regedit).
Mike Maltby MS-MVP
>> from http://aumha.org/regfiles.htm -
Reply to Anonymous
Personally, I have to go through configuring EditpadLite to open/edit .reg -
and all the other ascii-type files. The reg file is convenient, but I must
remember to edit it for Editpad and to set the others too, sometime!
Shane
"Mike M" <No_Spam@Corned_Beef.Only> wrote in message
news:OJdV0YwDFHA.2600@TK2MSFTNGP09.phx.gbl...
> Mike Maltby MS-MVP
Reply to Shane
I originally tried Editpad on Koldbear's recommendation. It must be the
anniversary of his death any day now. I've got some red coming back from
France tomorrow, think I'll raise a glass to the ol' bugger!
Shane
"Shane" <arthursixpence@hotmail.com> wrote in message
news:36voudF4dqddqU1@individual.net...
..reg -
> Shane
regedit
action
> > Mike Maltby MS-MVP
Reply to Shane
Thank you Shane for reminding me of Koldbear.
Dave
"Shane" <arthursixpence@hotmail.com> wrote in message news:36vp62F572nkjU1@individual.net...
| Shane
Reply to Anonymous
> CLASSES registry
> all?
> Thanks,
> Dave
Thank you all!! I really appreciate your help!
Dave,
Reply to Anonymous
Well, here we go, Dave.........(glass of red).........*To Koldbear!*
Shane
"David H. Lipman" <DLipman~nospam~@Verizon.Net> wrote in message
news:uIv7i2wDFHA.4004@tk2msftngp13.phx.gbl...
> Dave
> | Shane
Reply to Shane
A shot of JD -- in the memory of *Koldbear !*
< gulp >
Dave
news:eQuW7h8DFHA.2568@TK2MSFTNGP10.phx.gbl...
| Shane
| > Dave
| > | Shane
Reply to Anonymous
> regedit all that is necessary is to use Control Panel | Folder
> Options | File Types, select the REG extension, click Advanced and
> set the default action to Edit (to open in Notepad) or Merge (to run
> using Regedit).
That's easier than clicking a .REG file? <g>
Reply to Anonymous
Aren't you supposed to double click it? A considerable more effort than
just "clicking it". (Sorry Mike... and Jim, it's a wide open shot...)
John
Reply to Anonymous
> than just "clicking it". (Sorry Mike... and Jim, it's a wide open
> shot...)
On any Windows version from 98 onward, the option for single-click launch is
available ... and I do tend to assume that the rest of the world is as lazy
as me! <vbg>
Reply to Anonymous
> as me! <vbg>
So what do you do if you want to just highlight something or drag'n'drop ?
Rick
Reply to Anonymous
Yes, as it puts everything in the hand of the user rather than requiring
them to go to a third party site and download a tool to do it for them.
Better also perhaps in that they learn something about what they are
doing. :-)
Mike Maltby MS-MVP
>> using Regedit).
Reply to Anonymous
Well I'm just as lazy have been through 98 to XP <g>
Joan
> as me! <vbg>
Reply to Anonymous
Rick
I've used single-click for years, I can't understand anyone wanting to use
double-click.
To highlight something using single-click, just point at it.
To drag and drop, just point at it, and drag it.
George Gee
*Rick T* has posted this message:
drag'n'drop ?
Rick
>> launch is available ... and I do tend to assume that the rest of the
>> world is as lazy as me! <vbg>
Reply to Anonymous
> as me! <vbg>
You mean I have been doing all that work for the last 5 or 6 years for
nothing! All the lost time double clicking... time I could have spent
doing nothing instead. I think I'll go lie down and think about that
for a while...
John
Reply to Anonymous
> drag'n'drop ?
Highlight: Hold mouse over the item for a second or two
Drag-and-drop: Click-and-drag
Reply to Anonymous
>>drag'n'drop ?
thanks, thanks :)
Rick
Reply to Anonymous
There are 1166 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
