G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
got a new case yesterday and am pretty happy with it.
It came with an lcd display panel which is connected to three cables on
the inside of the case with temperature sensors at the endof each one.
One for sys (system), one for hdd (hard drive) and one for the cpu.
at the end of each cable the sensors them selves are shielded in a
plastic tube with the end open. (should I take the plastic tubes off ?)
I was wondering if anyone had any advice on how to use these, the case
did come with an instruction manual but it didn't really mention how or
where exactly to mount the sensors. I guess its probably not such a
good idea to shove the cpu sensor into the middle of the heatsink right ?.
Any help appreciated.
Eps
Eps
