Thorough scandisk problem
Archived from groups: microsoft.public.windowsme.general (More info?)
I have been trying to do a thorough scandisk for some time now and
cannot get it to finish. I don't get the usual restarts,
etc....it just gets to approximately the same point every time and
locks up. Can't exit, cancel etc.
I use the ScanDefrag program and it will work if I use the system
area option, but if I select the data area it gets to about 2053
and just stops and locks up. The defrag always works okay if I run
it by itself.
Any suggestions appreciated.
Janice
Dell Dimension L733r
WinMe with all updates
80 g hd
381 mb ram
nVidia Geforce4 mx440 graphics with 64 mb ram
6 answers Last reply
More about thorough scandisk problem
  1. Archived from groups: microsoft.public.windowsme.general (More info?)
    Janice, have you tried this ?
    ScanDefrag program > Help > Email ScanDefrag Team
    > it by itself.
    > Janice
    > 80 g hd
    > 381 mb ram
  2. Archived from groups: microsoft.public.windowsme.general (More info?)
    You *may* be seeing the early signs of a failing hard drive.
    Try running Scandisk in Real Mode DOS (N.B. Defrag does not work in this
    mode)
    Boot using your WinMe Startup (floppy) Disk and at the A:\> prompt, type:
    scandisk c: (Note the syntax - space between k and c followed by a colon)
    Then press return.
    If it shows errors, do not let it 'fix' them or do a Surface Test until you
    have backed up your data - you may need professional assistance if you're
    not sure how to copy or recover your data files.
    However, if you are prepared to lose data, then let it repair errors and do
    the surface scan.
    Hopefully - and with a bit of luck <g> - it may even fix the problem.
    Good luck
    Mart
    "granjan" <me@nospam.net> wrote in message
    news:%23h%23IK1DHFHA.3352@TK2MSFTNGP10.phx.gbl...
    > it by itself.
    > Janice
    > 80 g hd
    > 381 mb ram
  3. Archived from groups: microsoft.public.windowsme.general (More info?)
    Thanks...I'll give it a try and post back with results.
    "Mart" <mart(NoSpam)@nospam.com> wrote in message
    news:O6de55DHFHA.2704@tk2msftngp13.phx.gbl...
    in this
    | mode)
    prompt, type:
    a colon)
    | Then press return.
    Test until you
    if you're
    errors and do
    | the surface scan.
    problem.
    | Good luck
    | Mart
    and
    and
    system
    2053
    run
    | > it by itself.
    | > Janice
    | > 80 g hd
    | > 381 mb ram
  4. Archived from groups: microsoft.public.windowsme.general (More info?)
    No I haven't tried it. Thanks for the suggestion.
    "Kevin Moore" <kevinmoore@XoxymailX.org> wrote in message
    news:38c4h1F5ljt9sU1@individual.net...
    and
    and
    system
    2053
    run
    | > it by itself.
    | > Janice
    | > 80 g hd
    | > 381 mb ram
  5. Archived from groups: microsoft.public.windowsme.general (More info?)
    Okay...I did as you suggested and it ran for about 5 hours and was
    still only 58% thru but did not find any errors. I had to stop it
    and go to bed. I will retry the ScanDefrag program and if I still
    can't get it to run, I will try the suggestion of Kevin Moore.
    Thanks very much for your help.
    news:%23BOexAEHFHA.3076@tk2msftngp13.phx.gbl...
    work
    | in this
    | | mode)
    | prompt, type:
    by
    | a colon)
    | | Then press return.
    | Test until you
    assistance
    | if you're
    | errors and do
    | | the surface scan.
    | problem.
    | | Good luck
    | | Mart
    now
    | and
    time
    | and
    | system
    | 2053
    I
    | run
    | | > it by itself.
    | | > Janice
    | | > 80 g hd
    | | > 381 mb ram
  6. Archived from groups: microsoft.public.windowsme.general (More info?)
    5 hours does seem 'a rather long time' and *may* even be an indicator,
    however you MUST let it complete the scandisk to get any meaningful results.
    But by all means try Kevin's suggestion - my guess is that the ScanDefrag
    Team will initially point you in the same direction <g>
    Good luck with it.
    Mart
    news:uhEo9LQHFHA.1392@TK2MSFTNGP10.phx.gbl...
    > work
    > | in this
    > | | mode)
    > | prompt, type:
    > by
    > | a colon)
    > | | Then press return.
    > | Test until you
    > assistance
    > | if you're
    > | errors and do
    > | | the surface scan.
    > | problem.
    > | | Good luck
    > | | Mart
    > now
    > | and
    > time
    > | and
    > | system
    > | 2053
    > I
    > | run
    > | | > it by itself.
    > | | > Janice
    > | | > 80 g hd
    > | | > 381 mb ram
Windows
