Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > intel SE7210TP1-E - eps power supply problem - won't boot
Forum Homebuilt Systems : General Homebuilt - intel SE7210TP1-E - eps power supply problem - won't boot
Archived from groups: alt.comp.hardware.pc-homebuilt, comp.sys.ibm.pc.hardware.misc, comp.sys.intel, intel.motherboards (More info?)
Please help.
I have a intel SE7210TP1-E server board. It has worked fine (and still
does) with a Enlight 600W EPS power supply (EN-860B3E1). However, I
need this board to work with a different power supply. I bought an ams
mercury eps power supply (PP-4603EPS). Once plugged in and power
button hit all that would happen is the cpu fan would spin for a second
then nothing. Fearing this was due to a bad power supply, I sent it
back and got an antec EPS True 550 power supply. Same result.
I have removed the ram. same result. removed the cmos battery -
overnight. same result.
Each and every step I tried the orginal Enlight power supply with
success.
The reason I can't continue to use the enlight supply. Is that it does
not fit in the case that is now dedicated for this board.
Pulling my hair out.
And help would be appreciated.
Thanks
Dave
Sponsored Links
There are 487 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
