Archived from groups: microsoft.public.windowsme.general (
More info?)
It is not necessarily true that a program installs only fonts that it
needs. WordPerfect and Word install fonts you don't need, though it is
difficult to determine this. Some word processing applications will
let you install hundreds of "extra" fonts that are not needed.
I am afraid you have to be very careful in deleting the fonts and you
will have to look at each set of fonts to determine what application
installed them and whether you need all the fonts it installed.
Of course, if you installed fonts yourself, then only you know if you
really need them.
Look here for Windows fonts. Take Win98 SE as WinMe.
Fonts and products:
http://www.microsoft.com/typography/fonts/default.asp
You will also find them if you sort by date and have a look at Times
New Roman. The date should be 08-06-2000 (or 06-08-2000, depending on
your date format)
....Alan
Alan Edwards, MS MVP W95/98 Systems
http://dts-l.org/index.html
In microsoft.public.windowsme.general, Hillneerg
<Hillneerg@discussions.microsoft.com> wrote:
>The problem with deleting them is that, I would presume, the programs that
>installed them must actually need them. Would deleting them mean that the
>program would just display using standard windows fonts instead or could it
>cease to function?
>I have already fornd 57 fonds with a 0kb size so have dumped them. I have
>also downloaded a font manager (Fontlister) so, am I right in saying that I
>can copy the majority of fonts installed since the date I got the PC to a CD
>and, if there are any problems, just re-install that particular font?Also, is
>there somewhere where I can find a list of the fonts used by WinMe to ensure
>that I don't delete any of them?Thanks
>Hillneerg
>"Alan Edwards" wrote:
>> As you cannot possibly use all those fonts, just remove the ones you
>> don't need and get down under 500, although I usually recommend 250
>> maximum.
>> Copy them to another folder elsewhere before you delete them if you
>> have doubts. Sort the Fonts folder by date and you may get an idea as
>> to what programs installed them, as large applications often install
>> in blocks with the same date. Leave the fonts that came with Win Me
>> alone.
>> If you really want all those fonts, then use a font manager and only
>> install them when you need them.
>> ....Alan
>> >I have recently been getting a message box saying that I have over 500 fonts
>> >installed etc. On looking, I have around 800+, most of which have been
>> >installed by programs I have installed for teaching my disabled son.
>> >I realise about the maximum size in the registry etc but, if I delete the
>> >fonts, the programs won't work (I presume) as they need them.Is there a way
>> >around this? Everything seems to be working ok apart from the warning
>> >Thanks
