geforce fx 5600 fan noise?
bri
34
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
My fan on a geforce fx5600 is making a noise on startup, I have tried
cleaning it but no good.
Where can I get a replacement fan?
I have tried the shop I bought the card but they say there's noting they can
do?????
uk dealer would be handy
cheers
G
Guest
Guest
>do?????
>cheers
Hi Bri,
I am in Slough UK, and have a replacement fan. It is used, approx 1
month. I removed it from a FX5700LE to install a Zalman heatpipe
cooler. It had no unusual noises. You can have it, if you are prepared
to pay postage? Can send you a picture if you leave email address
Regards
Ray
bri
34
<<Hi Bri,
Regards
Ray>>
Thanks for the offer ray, I've got it sorted out......
thanks once again
G
Guest
Guest
> do?????
> cheers
check online case mod shops. plenty of HSF units (and silent units
without fans) available for that card.
spammage trappage: replace fishies_ with yahoo
I'm going to die rather sooner than I'd like. I tried to protect my
neighbours from crime, and became the victim of it. To jump to the end
of the story, as a result of this I need a bone marrow transplant. Many
people around the world are waiting for a marrow transplant, too. Please
volunteer to be a marrow donor:
http://www.abmdr.org.au/
http://www.marrow.org/
